The Cisco 10GBase SFP+ modules offer customers 10 Gigabit Ethernet connectivity options for data center, enterprise wiring closet, and service provider transport applications.
LINK LENGTH
Supports link lengths of 220 m on standard-grade FDDI multimode fibre; transmitter should be coupled through a mode conditioning patch cable for OM1 and OM2 (not required for applications over OM3 or OM4) -
COMPACT
Industry-smallest 10G form factor for greatest density per chassis -
HOT SWAPPABLE
Plugs into an Ethernet SFP+ port of a Cisco switch with no need to shut down if installing or replacing -
VERSATILITY
SFP receiver/transceiver module supports 'pay-as-you-populate' model for investment protection and ease of technology migration -
PEACE OF MIND
5-year standard replacement warranty
 - Cisco - SFP+ transceiver module - 10GbE
 - SFP+ transceiver module - LC/PC
- Form Factor
 - Plug-in module
- Cabling Type
 - 10GBase-LRM
- Data Transfer Rate
 - 10 Gbps
- Optical Wave Length
 - 1310 nm
- Data Link Protocol
 - 10GbE
- Max Transfer Distance
 - 300 m
 - 1.3 cm x 5.7 cm x 0.9 cm
 - 75 g
 - 90 days warranty
- Designed For
 - Nexus 93180YC-FX, 9372PX-E
- Form Factor
 - Plug-in module
- Connectivity Technology
 - Wired
- Cabling Type
 - 10GBase-LRM
 - 10GbE
 - 10 Gbps
 - 1310 nm
 - 300 m
 - IEEE 802.3ae
 - 1 x Ethernet 10GBase-LRM - LC/PC x 2
- Compatible Slots
 - 1 x SFP+
 - Laser Class 1, IEC 60825-1
 - 1.3 cm
 - 5.7 cm
 - 0.9 cm
 - 75 g
 - Limited warranty - 90 days
 - 0 °C
 - 70 °C
- Designed For
 - Cisco Nexus 93180YC-FX, 9372PX-E
