Cisco SFP+ Transceiver Module
Quicklinx: 9D0HWS00 Mfr#: DS-SFP-FC8G-SW=
Type: Modules
£158.71 ex VAT
£190.45 inc VAT
The Cisco Small Form-Factor Pluggable (SFP) for use on the Cisco MDS 9000 family of products are hot-swappable transceivers that plug into ports on the Cisco MDS 9000 family director switching modules and fabric switches. These transceivers give users the flexibility to choose different cabling types and distances on a port-by-port basis.
  • Enhanced connectivity
    Experience seamless data communication with the Cisco SFP+ transceiver module, designed to provide high-speed wired connectivity. With an 8.5 Gbps data transfer rate and support for 8Gb Fiber Channel (Short Wave), this module ensures efficient data transmission over fiber optic cabling.
  • Wide operating range
    Built to perform in a variety of conditions, the Cisco SFP+ transceiver module operates effectively within a temperature range of 0°C to 40°C. This wide operating range ensures reliability and performance stability in diverse environmental conditions.
  • Extended reach
    The Cisco SFP+ transceiver module boasts a maximum transfer distance of 520 m, enabling long-distance communication without signal degradation. This feature is particularly beneficial for expansive network setups requiring reliable data transmission over considerable distances.
Cisco - SFP+ transceiver module - 8Gb Fibre Channel (SW)
SFP+ transceiver module - LC multi-mode
Plug-in module
Cabling Type
Fibre optic
Data Transfer Rate
8.5 Gbps
Optical Wave Length
850 nm
Max Transfer Distance
520 m
1.4 cm x 5.7 cm x 0.9 cm
MDS 9509 Fibre Channel Director, 9509 Multilayer Director, 9513 Multilayer Director
Plug-in module
Wired
Cabling Type
Fibre optic
Data Transfer Rate
8.5 Gbps
Optical Wave Length
850 nm
520 m
1 x 8Gb Fibre Channel (SW) - LC multi-mode x 2
Compatible Slots
1 x SFP+
1.4 cm
5.7 cm
0.9 cm
Cisco MDS 9509 Fibre Channel Director, 9509 Multilayer Director, 9513 Multilayer Director
Type: Modules
Brand: Cisco
