The Cisco 10GBase SFP+ modules offer customers 10 Gigabit Ethernet connectivity options for data center, enterprise wiring closet, and service provider transport applications.
                LINK LENGTHSupports link lengths of 220 m on standard-grade FDDI multimode fibre; transmitter should be coupled through a mode conditioning patch cable for OM1 and OM2 (not required for applications over OM3 or OM4)
                COMPACTIndustry-smallest 10G form factor for greatest density per chassis
                HOT SWAPPABLEPlugs into an Ethernet SFP+ port of a Cisco switch with no need to shut down if installing or replacing
                VERSATILITYSFP receiver/transceiver module supports 'pay-as-you-populate' model for investment protection and ease of technology migration
                PEACE OF MIND5-year standard replacement warranty
- Cisco - SFP+ transceiver module - 10GbE
- SFP+ transceiver module - LC/PC
- Form Factor
- Plug-in module
- Cabling Type
- 10GBase-LRM
- Data Transfer Rate
- 10 Gbps
- Optical Wave Length
- 1310 nm
- Data Link Protocol
- 10GbE
- Max Transfer Distance
- 300 m
- 1.3 cm x 5.7 cm x 0.9 cm
- 75 g
- 90 days warranty
- Designed For
- Nexus 93180YC-FX, 9372PX-E
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 10GBase-LRM
- 10GbE
- 10 Gbps
- 1310 nm
- 300 m
- IEEE 802.3ae
- 1 x Ethernet 10GBase-LRM - LC/PC x 2
- Compatible Slots
- 1 x SFP+
- Laser Class 1, IEC 60825-1
- 1.3 cm
- 5.7 cm
- 0.9 cm
- 75 g
- Limited warranty - 90 days
- 0 °C
- 70 °C
- Designed For
- Cisco Nexus 93180YC-FX, 9372PX-E
