Cisco SFP+ Transceiver Module
Quicklinx: 95N6WS00 Mfr#: SFP-10G-LRM=
Type: Modules
21 In Stock
£426.40 ex VAT
£511.68 inc VAT
The Cisco 10GBase SFP+ modules offer customers 10 Gigabit Ethernet connectivity options for data center, enterprise wiring closet, and service provider transport applications.
  • LINK LENGTH
    Supports link lengths of 220 m on standard-grade FDDI multimode fibre; transmitter should be coupled through a mode conditioning patch cable for OM1 and OM2 (not required for applications over OM3 or OM4)
  • COMPACT
    Industry-smallest 10G form factor for greatest density per chassis
  • HOT SWAPPABLE
    Plugs into an Ethernet SFP+ port of a Cisco switch with no need to shut down if installing or replacing
  • VERSATILITY
    SFP receiver/transceiver module supports 'pay-as-you-populate' model for investment protection and ease of technology migration
  • PEACE OF MIND
    5-year standard replacement warranty
Cisco - SFP+ transceiver module - 10GbE
SFP+ transceiver module - LC/PC
Plug-in module
Cabling Type
10GBase-LRM
Data Transfer Rate
10 Gbps
Optical Wave Length
1310 nm
10GbE
Max Transfer Distance
300 m
1.3 cm x 5.7 cm x 0.9 cm
75 g
90 days warranty
Nexus 93180YC-FX, 9372PX-E
Plug-in module
Wired
Cabling Type
10GBase-LRM
10GbE
Data Transfer Rate
10 Gbps
Optical Wave Length
1310 nm
300 m
IEEE 802.3ae
1 x Ethernet 10GBase-LRM - LC/PC x 2
Compatible Slots
1 x SFP+
Laser Class 1, IEC 60825-1
1.3 cm
5.7 cm
0.9 cm
75 g
Limited warranty - 90 days
70 °C
Cisco Nexus 93180YC-FX, 9372PX-E
Type: Modules
Brand: Cisco
