Cisco SFP+ Transceiver Module 10 Gigabit Ethernet 10GBase-SR LC/PC multi-mode up to 400 m - 850 nm
Quicklinx: CB36WS00 Mfr#: SFP-10G-SR-S=
More than 50 In Stock
£255.83 ex VAT
£306.99 inc VAT
The Cisco S-Class 10GBASE SFP+ modules (Figure 1) offer customers a variety of 10 Gigabit Ethernet connectivity options optimized for Enterprise and data center applications. S-Class optics are available for the most common reaches needed for these applications.
  • LINK LENGTH
    Supports link lengths of 26 m on standard FDDI-grade multimode fiber; up to 300 m link lengths possible using OM3 and 400 m using OM4 (this model does not support Fiber Channel over Ethernet [FCoE])
  • COMPACT
    Industry-smallest 10G form factor for greatest density per chassis
  • HOT SWAPPABLE
    Plugs into an Ethernet SFP+ port of a Cisco switch with no need to shut down if installing or replacing
  • VERSATILITY
    SFP receiver/transceiver module supports 'pay-as-you-populate' model for investment protection and ease of technology migration
  • PEACE OF MIND
    5-year standard replacement warranty
Cisco - SFP+ transceiver module - 10GbE
SFP+ transceiver module - LC/PC multi-mode
Plug-in module
Cabling Type
10GBase-SR
Data Transfer Rate
10 Gbps
Optical Wave Length
850 nm
10GbE
Max Transfer Distance
400 m
1.3 cm x 5.7 cm x 0.9 cm
75 g
1-year warranty
Plug-in module
Wired
Cabling Type
10GBase-SR
10GbE
Data Transfer Rate
10 Gbps
Optical Wave Length
850 nm
400 m
IEEE 802.3ae
1 x Ethernet 10GBase-SR - LC/PC multi-mode x 2
1.3 cm
5.7 cm
0.9 cm
75 g
Limited warranty - 1 year
70 °C
Brand: Cisco
