Cisco SFP+ Transceiver Module 10 Gigabit Ethernet 10GBase-LR LC/PC
Quicklinx: CX57WS00 Mfr#: SFP-10G-LR=
Hurry, only 1 left in stock!
£1,522.09 ex VAT
£1,826.50 inc VAT
The Cisco 10GBASE SFP+ modules offer customers a wide variety of 10 Gigabit Ethernet connectivity options for data center, enterprise wiring closet, and service provider transport applications.
The Cisco 10GBASE-LR Module supports a link length of 10 kilometers on standard single-mode fiber (SMF, G.652).
  • LINK LENGTH
    Supports a link length of 10 km on standard single-mode fibre
  • COMPACT
    Industry-smallest 10G form factor for greatest density per chassis
  • HOT SWAPPABLE
    Plugs into an Ethernet SFP+ port of a Cisco switch with no need to shut down if installing or replacing
  • VERSATILITY
    SFP receiver/transceiver module supports 'pay-as-you-populate' model for investment protection and ease of technology migration
  • PEACE OF MIND
    5-year standard replacement warranty
Cisco - SFP+ transceiver module - 10GbE
SFP+ transceiver module - LC/PC single-mode
Plug-in module
Cabling Type
10GBase-LR
Data Transfer Rate
10 Gbps
Optical Wave Length
1310 nm
10GbE
Max Transfer Distance
10 km
1.3 cm x 5.7 cm x 0.9 cm
75 g
90 days warranty
Catalyst ESS9300 Embedded Series, Switch Module 3012 for IBM BladeCenter, Switch Module 3110G for IBM BladeCenter, Switch Module 3110X for IBM BladeCenter; Nexus 5010
Plug-in module
Wired
Cabling Type
10GBase-LR
10GbE
Data Transfer Rate
10 Gbps
Optical Wave Length
1310 nm
10 km
IEEE 802.3ae
1 x Ethernet 10GBase-LR - LC/PC single-mode x 2
Compatible Slots
1 x SFP+
1.3 cm
5.7 cm
0.9 cm
75 g
Limited warranty - 90 days
70 °C
Cisco Catalyst ESS9300 Embedded Series, Switch Module 3012 for IBM BladeCenter, Switch Module 3110G for IBM BladeCenter, Switch Module 3110X for IBM BladeCenter , Cisco Nexus 5010
CX57 Cisco 10GBASE-CU SFP+ CABLE 5 METER In Stock £114.29
CX57 Cisco 10GBASE-CU SFP+ Cable 1 Meter In Stock £76.22
CX57 Cisco SFP+ Copper Twinax Cable - SFP+ - SFP+ - 3m In Stock £62.35
CX57 Cisco SFP+ Copper Twinax Cable 2m - Brown In Stock £102.11
Brand: Cisco
Price Range Ex VAT: £1500+
