The Cisco 10GBASE SFP+ modules offer customers a wide variety of 10 Gigabit Ethernet connectivity options for data center, enterprise wiring closet, and service provider transport applications.
The Cisco 10GBASE-LR Module supports a link length of 10 kilometers on standard single-mode fiber (SMF, G.652).
LINK LENGTH
Supports a link length of 10 km on standard single-mode fibre -
COMPACT
Industry-smallest 10G form factor for greatest density per chassis -
HOT SWAPPABLE
Plugs into an Ethernet SFP+ port of a Cisco switch with no need to shut down if installing or replacing -
VERSATILITY
SFP receiver/transceiver module supports 'pay-as-you-populate' model for investment protection and ease of technology migration -
PEACE OF MIND
5-year standard replacement warranty
 - Cisco - SFP+ transceiver module - 10GbE
 - SFP+ transceiver module - LC/PC single-mode
- Form Factor
 - Plug-in module
- Cabling Type
 - 10GBase-LR
- Data Transfer Rate
 - 10 Gbps
- Optical Wave Length
 - 1310 nm
- Data Link Protocol
 - 10GbE
- Max Transfer Distance
 - 10 km
 - 1.3 cm x 5.7 cm x 0.9 cm
 - 75 g
 - 90 days warranty
- Designed For
 - Catalyst ESS9300 Embedded Series, Switch Module 3012 for IBM BladeCenter, Switch Module 3110G for IBM BladeCenter, Switch Module 3110X for IBM BladeCenter; Nexus 5010
- Form Factor
 - Plug-in module
- Connectivity Technology
 - Wired
- Cabling Type
 - 10GBase-LR
 - 10GbE
 - 10 Gbps
 - 1310 nm
 - 10 km
 - IEEE 802.3ae
 - 1 x Ethernet 10GBase-LR - LC/PC single-mode x 2
- Compatible Slots
 - 1 x SFP+
 - 1.3 cm
 - 5.7 cm
 - 0.9 cm
 - 75 g
 - Limited warranty - 90 days
 - 0 °C
 - 70 °C
- Designed For
 - Cisco Catalyst ESS9300 Embedded Series, Switch Module 3012 for IBM BladeCenter, Switch Module 3110G for IBM BladeCenter, Switch Module 3110X for IBM BladeCenter , Cisco Nexus 5010
                        Cisco 10GBASE-CU SFP+ CABLE 5 METER | In Stock | £117.44 |
                        Cisco 10GBASE-CU SFP+ Cable 1 Meter | In Stock | £78.27 |
                        Cisco SFP+ Copper Twinax Cable - SFP+ - SFP+ - 3m | In Stock | £64.13 |
                        Cisco SFP+ Copper Twinax Cable 2m - Brown | In Stock | £103.22 |
