Cisco SFP+ Transceiver Module - 16GB Fibre Channel (SW) - Fibre Op
Quicklinx: DYCHWS00 Mfr#: DS-SFP-FC16G-SW=
£285.10 ex VAT
£342.12 inc VAT
The Cisco 16-Gbps Fiber Channel SFP+ transceiver is designed to provide Fiber Channel connectivity for the 16-Gbps ports.
  • Enhanced connectivity
    With a data transfer rate of 16 Gbps and connectivity over a distance of up to 400 m, this SFP+ transceiver module ensures high-speed, reliable connections for your networking needs.
  • Versatile compatibility
    Designed for PC compatibility and equipped with dual LC multi-mode connectors, this module seamlessly integrates into existing setups, enhancing your system's performance without the need for extensive modifications.
  • Optimal performance
    Operating efficiently within a wide temperature range from 0°C to 40°C, this module is built to maintain optimal performance in various environmental conditions, ensuring consistent, high-quality connections.
Cisco - SFP+ transceiver module - 16Gb Fibre Channel (SW)
SFP+ transceiver module - LC multi-mode
Plug-in module
Cabling Type
Fibre optic
Data Transfer Rate
16 Gbps
Optical Wave Length
850 nm
Max Transfer Distance
400 m
1.4 cm x 5.7 cm x 0.9 cm
Nexus 93180YC-FX
Plug-in module
Wired
Cabling Type
Fibre optic
Data Transfer Rate
16 Gbps
Optical Wave Length
850 nm
400 m
1 x 16Gb Fibre Channel (SW) - LC multi-mode x 2
Compatible Slots
1 x SFP+
1.4 cm
5.7 cm
0.9 cm
Cisco Nexus 93180YC-FX
Brand: Cisco
