Cisco SF110D-16HP 16-Port Unmanaged Desktop PoE+ Switch
Quicklinx: CVDZWS00 Mfr#: SF110D-16HP-UK
Type: Fast Ethernet
Ports: 16
Managed: No
POE: PoE
£133.28 ex VAT
£159.93 inc VAT
Part of the Cisco Small Business Series of networking solutions, Cisco 100 Series Unmanaged Switches deliver wire-speed Fast Ethernet or Gigabit Ethernet connectivity to connect your small business office. These switches are designed to suit any office space and help optimize power efficiency. They provide long-term investment protection and support for advanced features like quality of service (QoS) - all in a switch that you can set up by yourself in just minutes.
  • ETHERNET PORT CONFIGURATION
    16-port 10/100M
  • POWER OVER ETHERNET
    8 PoE ports with 64W total power budget
  • PLUG AND PLAY
    Simple set up with no software to install or configuration needed
  • PEACE OF MIND
    Limited-lifetime warranty and one-year technical support
  • ENERGY EFFICIENT
    Optimizes power usage to lower cost to operate. Compliant with IEEE802.3az Energy Efficient Ethernet
Cisco Small Business SF110D-16HP - switch - 16 ports - unmanaged
Switch - 16 ports - unmanaged
Subtype
Fast Ethernet
Ports
8 x 10/100 + 8 x 10/100 (PoE)
Power Over Ethernet (PoE)
PoE
PoE Budget
64 W
Performance
Switching capacity: 3.2 Gbps , Forwarding performance (64-byte packet size): 1.4 Mpps
QoS hardware queues: 4
Jumbo Frame Support
9216 bytes
Auto-uplink (auto MDI/MDI-X), Weighted Round Robin (WRR) queuing, Quality of Service (QoS), fanless, Energy Efficient Ethernet, security lock slot (cable lock sold separately), cable test
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3az
AC 120/230 V (50 - 60 Hz)
16 cm x 9 cm x 4.3 cm
450 g
United Kingdom
Enclosure Type
Desktop, wall-mountable
Subtype
Fast Ethernet
Ports
PoE
PoE Budget
64 W
Performance
Jumbo Frame Support
9216 bytes
RAM
128 MB
Flash Memory
128 MB
Status Indicators
System, link/activity
8 x 100Base-TX RJ-45 , 8 x 100Base-TX RJ-45 PoE
Internal power supply
UL 60950, FCC CFR47 Part 15, CSA 22.2
United Kingdom
16 cm
9 cm
4.3 cm
450 g
Limited warranty - lifetime
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
CVDZ Cisco Gigabit Ethernet SX Mini-GBIC In Stock £101.46
CVDZ Cisco Gigabit Ethernet LX Mini-GBIC SFP Transceiver In Stock £131.82
Type: Fast Ethernet
Ports: 16
Managed: No
POE: PoE
Brand: Cisco
