Cisco 300 series switch delivers the ideal combination of price, performance, and capabilities in a solution designed specifically for small businesses. This broad portfolio of affordable managed switch provides a powerful foundation to support your business network.
High performance and reliability
Get the high availability and performance you need to support vital business applications while reducing downtime. -
Advanced features
Control network traffic with advanced features such as quality of service (QoS), Layer 3 static routing, and IPv6 support. -
Easy setup and management
Intuitive browser-based tools, mass deployment capabilities, and consistent features across all models simplify setup and configuration. -
An eco-friendly solution
Switches optimize power usage for energy efficiency without compromising performance. -
Advanced features
Strong security features include access control lists (ACLs), guest virtual LANs (VLANs), and other advanced security features to tightly control networks. IPv6 support allows you to move up to the next generation of networking applications and operating systems without an extensive equipment upgrade. Quality of service (QoS) on all models prioritizes network traffic to keep critical network applications running at top performance. -
Energy efficiency and design
It support of Energy Efficient Ethernet (EEE) and reduction of energy consumption by monitoring traffic and putting links into sleep mode during quiet periods. Power-saving technology allows switch to enter sleep mode, turn off unused ports, and adjust power as needed. Fanless design on several models allows switches to run silently and unobtrusively. LEDs can be turned off to save power.
- Cisco Small Business SF300-24P - switch - 24 ports - Managed
- Switch - 24 ports - L3 - Managed
- Enclosure Type
- 1U
- Subtype
- Fast Ethernet
- Ports
- 24 x 10/100 (PoE) + 2 x combo Gigabit SFP + 2 x 10/100/1000
- Power Over Ethernet (PoE)
- PoE
- MAC Address Table Size
- 8K entries
- Routing Protocol
- Static IPv4 routing
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, CLI
- Layer 3 switching, Layer 2 switching, DHCP support, BOOTP support, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, WRR queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, firmware upgradable, STP support, RSTP support, MSTP support, TFTP support, ACL support, QoS, Jumbo Frames support, MLD snooping
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s
- Power
- AC 120/230 V (50/60 Hz)
- 44 cm x 25.7 cm x 4.5 cm
- 3.7 kg
- Localisation
- Chinese (simplified), English, German, French, Italian, Spanish, Japanese / Europe
- Limited lifetime warranty
- Enclosure Type
- Desktop 1U
- Subtype
- Fast Ethernet
- Ports
- PoE
- 8K entries
- Routing Protocol
- Encryption Algorithm
- SSL
- Authentication Method
- Secure Shell (SSH), RADIUS, TACACS+
- RAM
- 128 MB
- Flash Memory
- 16 MB Flash
- Status Indicators
- Port transmission speed, system, link/activity
- 24 x 100Base-TX RJ-45 PoE , 1 x console DB-9 management , 4 x 1000Base-T RJ-45 , 2 x SFP (mini-GBIC)
- Power Device
- Internal power supply
- Voltage Required
- Cables Included
- 1 x serial cable
- Rack Mounting Kit
- Included
- UL 60950, CSA 22.2 No. 60950, FCC Part 15 A
- Localisation
- 44 cm
- 25.7 cm
- 4.5 cm
- 3.7 kg
- Limited warranty - replacement - lifetime - response time: next business day
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
