Cisco SA 500 Series Security Appliances are all-in-one security solutions for businesses with fewer than 100 employees. Designed specifically for small business, they combine firewall, virtual private network (VPN), and email and web security capabilities. Whether in the office or working remotely, your employees can securely access the resources they need, while your business is protected from unauthorized access and Internet threats.
All-in-one device
Combines firewall, email and web security, and secure access in one box. -
Secure wireless and remote access
Easily allow mobile workers and branch offices to remotely and securely access the network with flexible and easy to use built-in VPN support. -
Low overhead
Reduce costs associated with deployment and ongoing management and monitoring of the security solution by using a single, easy-to-install, easy-to-use solution. -
Increased security of remote access
With support for optional VeriSign Identity Protection (VIP), the Cisco SA 500 Series provides two-factor authentication and one-time-use password access control.
- Cisco Small Business Pro SA 540 - security appliance
- Security appliance
- Form Factor
- External - 1U
- Ports Qty
- 8
- Data Link Protocol
- Performance
- Stateful throughput: 300 Mbps , Unified Threat Management (UTM) throughput: 300 Mbps , VPN throughput (3DES/AES): 85 Mbps
- Capacity
- Connection / user qty: 40000 , Matching rules: 100 , IPSec VPN tunnels: 100 , SSL VPN tunnels: 50 , Authenticated users (internal database): 400 , Virtual interfaces (VLANs): 16
- Power
- AC 120/230 V (50/60 Hz)
- 30.8 cm x 18 cm x 4.4 cm
- 2.34 kg
- 1-year warranty
- Height (Rack Units)
- 1U
- 30.8 cm
- 18 cm
- 4.4 cm
- 2.34 kg
- Form Factor
- External
- Ports Qty
- 8
- Connectivity Technology
- Wired
- Switching Protocol
- Ethernet
- Routing Protocol
- RIP-1, RIP-2, static IP routing
- Remote Management Protocol
- SNMP 1, SNMP 2c, HTTP, HTTPS
- Performance
- Capacity
- Status Indicators
- Port status, power, WAN, LAN, link/activity, diagnostic
- Firewall protection, DHCP support, NAT support, VPN support, PAT support, NAPT support, load balancing, VLAN support, Stateful Packet Inspection (SPI), content filtering, ALG support, dynamic DNS server, port mirroring, IPv6 support, antivirus analysis, Intrusion Prevention System (IPS), URL filtering, firmware upgradable, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, anti-spam protection, event log, Access Control List (ACL) support, Quality of Service (QoS), IPSec NAT-Traversal (NAT-T), IPSec passthrough, anti-spyware protection, anti-phishing protection, web threat protection
- Encryption Algorithm
- DES, Triple DES, MD5, AES, SHA-1, PEAP
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.1x
- 8 x 1000Base-T - RJ-45 , 1 x 1000Base-T - RJ-45 (WAN) , 1 x USB 2.0 - Type A , 1 x 1000Base-T - RJ-45 (LAN / DMZ / WAN)
- FCC Class B certified, ICES-003
- Power Device
- Internal power supply
- Voltage Required
- OS Provided
- Linux
- Limited warranty - replacement - 1 year , New releases update - 90 days
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
