Cisco SA 520 Security Appliance With Wireless
Quicklinx: 6CLVWS00 Mfr#: SA520W-K9
  • IEEE 802.11n
Cisco SA 500 Series Security Appliances are all-in-one security solutions for businesses with fewer than 100 employees. Designed specifically for small business, they combine firewall, virtual private network (VPN), and email and web security capabilities. Whether in the office or working remotely, your employees can securely access the resources they need, while your business is protected from unauthorized access and Internet threats.
  • All-in-one device
    Combines firewall, email and web security, and secure access in one box.
  • Secure wireless and remote access
    Easily allow mobile workers and branch offices to remotely and securely access the network with flexible and easy to use built-in VPN support.
  • Low overhead
    Reduce costs associated with deployment and ongoing management and monitoring of the security solution by using a single, easy-to-install, easy-to-use solution.
  • Increased security of remote access
    With support for optional VeriSign Identity Protection (VIP), the Cisco SA 500 Series provides two-factor authentication and one-time-use password access control.
Cisco Small Business Pro SA 520W - security appliance - Wi-Fi
Security appliance
External - 1U
Ports Qty
6
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Performance
Stateful throughput: 200 Mbps , Unified Threat Management (UTM) throughput: 200 Mbps , VPN throughput (3DES/AES): 65 Mbps
Connection / user qty: 15000 , Matching rules: 100 , IPSec VPN tunnels: 50 , SSL VPN tunnels: 2 , Authenticated users (internal database): 100 , Virtual interfaces (VLANs): 16
30.8 cm x 18 cm x 4.4 cm
2.34 kg
1-year warranty
Security appliance
Height (Rack Units)
1U
30.8 cm
18 cm
4.4 cm
2.34 kg
External
Ports Qty
6
Wireless, wired
Switching Protocol
Ethernet
Routing Protocol
RIP-1, RIP-2, static IP routing
Remote Management Protocol
SNMP 1, SNMP 2c, HTTP, HTTPS
Frequency Band
2.4 GHz
Performance
Status Indicators
Port status, power, WAN, LAN, link/activity, diagnostic
Firewall protection, DHCP support, NAT support, VPN support, PAT support, NAPT support, load balancing, VLAN support, Stateful Packet Inspection (SPI), content filtering, ALG support, dynamic DNS server, port mirroring, MAC address filtering, IPv6 support, antivirus analysis, Intrusion Prevention System (IPS), URL filtering, firmware upgradable, MIMO technology, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Wi-Fi Multimedia (WMM) support, anti-spam protection, event log, Access Control List (ACL) support, Quality of Service (QoS), IPSec NAT-Traversal (NAT-T), Wi-Fi Protected Setup (WPS), IPSec passthrough, anti-spyware protection, anti-phishing protection, web threat protection
Encryption Algorithm
DES, Triple DES, MD5, AES, SHA-1, PEAP, WPA2-PSK, WPA2-Enterprise
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11e, IEEE 802.11n
Aerial
Antenna
External detachable
Antenna Qty
3
4 x 1000Base-T - RJ-45 , 1 x 1000Base-T - RJ-45 (WAN) , 1 x USB 2.0 - Type A , 1 x 1000Base-T - RJ-45 (LAN / DMZ / WAN)
FCC Class B certified, ICES-003
Internal power supply
OS Provided
Linux
Limited warranty - replacement - 1 year , New releases update - 90 days
10 - 90% (non-condensing)
