The Cisco RV110W Wireless-N VPN Firewall combines simple, highly secure wired and wireless connectivity for small offices/home offices and remote workers with a high-speed, 802.11n wireless access point; a 4-port 10/100 Mbps Fast Ethernet switch; an intuitive, browser-based device manager; and support for the Cisco FindIT Network Discovery Utility, at a very affordable price. Its combination of business-class features, support for virtual networks to enable highly secure guest access, simple installation, and top-quality user experience takes basic connectivity for a small business with five or fewer employees to a new level.
- Cisco Small Business RV110W - wireless router - Wi-Fi - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Performance
- NAT throughput: 90 Mbps , VPN throughput (IPSec): 5 Mbps
- Capacity
- Concurrent sessions: 5000 , IPSec VPN tunnels: 5 , PPTP VPN tunnels: 5 , Active VLANs: 4
- PPTP, L2TP, ICMP/IP, IPSec, PPPoE, DHCP, Bonjour, DDNS
- Routing Protocol
- RIP-1, RIP-2, IGMP, static IPv6 routing, RIPng
- Remote Management Protocol
- SNMP 3, HTTP, HTTPS
- NAT support, PAT support, VLAN support, Syslog support, SPI, DoS attack prevention, dynamic DNS server, port mirroring, E-mail alert, IPv6 support, VPN passthrough, WDS support, firmware upgradable, RSTP support, WMM support, event log, ACL support, QoS, WPS, DHCP server, Multiple SSID support, DNS proxy, port forwarding, IPv4 support, DSSS
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11e, IEEE 802.11n, UPnP
- Power
- 1 A
- 15 cm x 15 cm x 3 cm
- 279 g
- Localisation
- English / Europe
- Limited lifetime warranty
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- Selectable Channels Qty
- 13
- Performance
- Capacity
- Routing Protocol
- Encryption Algorithm
- Triple DES, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
- Authentication Method
- Radio Service Set ID (SSID)
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11e, IEEE 802.11n, UPnP, FCC Class B certified, cUL, IC
- Status Indicators
- Power, WAN, LAN, wireless
Line Properties
- Line Coding Format
- OFDM
- LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45
Aerial
- Aerial
- External integrated
- Antenna Qty
- 2
- Directivity
- Omni-directional
- Gain Level
- 1.8 dBi
- Power Device
- External power adapter
- Electric Current Required
- 1 A
- Cables Included
- 1 x network cable
- Localisation
- English / Europe
- OS Provided
- Linux
- Software Included
- Drivers & Utilities
- 15 cm
- 15 cm
- 3 cm
- 279 g
- 0 °C
- 40 °C
- 10 - 85% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.67 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £9.82 |
