Cisco Rack-Mount Kit - Catalyst 2960-X Series for 19" - 24" Racks
Quicklinx: 9B0QWS00 Mfr#: RCKMNT-1RU-2KX=
  • RACK MOUNT
    For mounting Cisco Catalyst network switches
  • EASY INSTALLATION
    Kit includes two metal brackets and four screws
  • COMPATIBILITY
    For use with Cisco Catalyst 2960-X, 2960-XR and 2960-L network switches
  • CAUTION
    Install network switch with front panel facing down to allow sufficient airflow; allow at least 3 inches (7.6 cm) of clearance around ventilation openings
  • PEACE OF MIND
    Enhanced limited lifetime warranty
Cisco rack mounting kit - 19"/24"
Rack mounting kit
Catalyst 2960X-24, 2960X-48, 2960XR-24, 2960XR-48
Rack mounting kit
Rack Size
19"/24"
Cisco Catalyst 2960X-24PD-L, 2960X-24PS-L, 2960X-24PSQ-L, 2960X-24TD-L, 2960X-24TS-L, 2960X-24TS-LL, 2960X-48FPD-L, 2960X-48FPS-L, 2960X-48LPD-L, 2960X-48LPS-L, 2960X-48TD-L, 2960X-48TS-L, 2960X-48TS-LL, 2960XR-24PD-I, 2960XR-24PS-I, 2960XR-24TD-I, 2960XR-24TS-I, 2960XR-48FPD-I, 2960XR-48FPS-I, 2960XR-48LPD-I, 2960XR-48LPS-I, 2960XR-48TD-I, 2960XR-48TS-I
