RACK MOUNT
For mounting Cisco Catalyst network switches -
EASY INSTALLATION
Kit includes two metal brackets and four screws -
COMPATIBILITY
For use with Cisco Catalyst 2960-X, 2960-XR and 2960-L network switches -
CAUTION
Install network switch with front panel facing down to allow sufficient airflow; allow at least 3 inches (7.6 cm) of clearance around ventilation openings -
PEACE OF MIND
Enhanced limited lifetime warranty
- Cisco rack mounting kit - 19"/24"
- Product Type
- Rack mounting kit
- Designed For
- Catalyst 2960X-24, 2960X-48, 2960XR-24, 2960XR-48
- Product Type
- Rack mounting kit
- Rack Size
- 19"/24"
- Designed For
- Cisco Catalyst 2960X-24PD-L, 2960X-24PS-L, 2960X-24PSQ-L, 2960X-24TD-L, 2960X-24TS-L, 2960X-24TS-LL, 2960X-48FPD-L, 2960X-48FPS-L, 2960X-48LPD-L, 2960X-48LPS-L, 2960X-48TD-L, 2960X-48TS-L, 2960X-48TS-LL, 2960XR-24PD-I, 2960XR-24PS-I, 2960XR-24TD-I, 2960XR-24TS-I, 2960XR-48FPD-I, 2960XR-48FPS-I, 2960XR-48LPD-I, 2960XR-48LPS-I, 2960XR-48TD-I, 2960XR-48TS-I
