Cisco is the worldwide leader in networking for the Internet. Cisco provides the broadest line of solutions for transporting data, voice and video within buildings, across campuses, or around the world. Cisco solutions ensure that networks both public and private operate with maximum performance, security, and flexibility.
Robust compatibility
Designed to seamlessly integrate with network hardware and power equipment, this power supply ensures reliable performance across a variety of devices. -
Wide operating range
With an operating temperature range from -5°C to 45°C and humidity range from 10 to 85%, this power supply is built to withstand challenging environmental conditions. -
Comprehensive safety standards
Meets a broad spectrum of compliance standards including AS/NZS 60950-1, FCC Class A certified, and UL 60950-1, ensuring a high level of safety and reliability for your critical network infrastructure.
- Cisco - power supply - hot-plug - 1150 Watt
- Power supply - hot-plug - plug-in module
- 2.6 kg
- Power Capacity
- 1150 Watt
- Input Connectors
- Power IEC 60320 C13
- 15.2 cm x 37.9 cm x 4.2 cm
- Designed For
- Catalyst 3560E-24PD, 3560E-24TD, 3560E-48PD, 3560E-48PD-F, 3560E-48TD, 3560E-48TD-SD, 3560V2-24PS, 3560V2-24TS, 3560V2-24TS-SD, 3560V2-48PS, 3560V2-48TS, 3750E-24PD, 3750E-24TD, 3750E-48PD, 3750E-48PD-F, 3750E-48TD; Redundant Power System 2300
- Input Voltage Range
- AC 115 - 240 V
- Frequency Required
- 50 - 60 Hz
- Input Connectors
- Power Capacity
- 1150 Watt
- FCC Class A certified, BSMI, CISPR 22 Class A, GOST, CISPR 24, NOM, VCCI Class A ITE, EN55024, EN55022 Class A, AS/NZS 60950-1, CCC, FCC Part 15, MIC, UL 60950-1, IEC 60950-1, EN 60950-1
- -5 °C
- 45 °C
- 10 - 85%
- 15.2 cm
- 37.9 cm
- 4.2 cm
- 2.6 kg
- Designed For
- Cisco Catalyst 3560E-24PD, 3560E-24TD, 3560E-48PD, 3560E-48PD-F, 3560E-48TD, 3560E-48TD-SD, 3560V2-24PS, 3560V2-24TS, 3560V2-24TS-SD, 3560V2-48PS, 3560V2-48TS, 3750E-24PD, 3750E-24TD, 3750E-48PD, 3750E-48PD-F, 3750E-48TD , Cisco Redundant Power System 2300
Cisco Power supply Hot-Plug (plug-in module) - 1150 Watt
