Cisco Power supply Hot-Plug (plug-in module) - 1150 Watt
Quicklinx: D4M1WS00 Mfr#: C3K-PWR-1150WAC=
Cisco is the worldwide leader in networking for the Internet. Cisco provides the broadest line of solutions for transporting data, voice and video within buildings, across campuses, or around the world. Cisco solutions ensure that networks both public and private operate with maximum performance, security, and flexibility.
  • Robust compatibility
    Designed to seamlessly integrate with network hardware and power equipment, this power supply ensures reliable performance across a variety of devices.
  • Wide operating range
    With an operating temperature range from -5°C to 45°C and humidity range from 10 to 85%, this power supply is built to withstand challenging environmental conditions.
  • Comprehensive safety standards
    Meets a broad spectrum of compliance standards including AS/NZS 60950-1, FCC Class A certified, and UL 60950-1, ensuring a high level of safety and reliability for your critical network infrastructure.
Cisco - power supply - hot-plug - 1150 Watt
Power supply - hot-plug - plug-in module
2.6 kg
Power Capacity
1150 Watt
Input Connectors
Power IEC 60320 C13
15.2 cm x 37.9 cm x 4.2 cm
Catalyst 3560E-24PD, 3560E-24TD, 3560E-48PD, 3560E-48PD-F, 3560E-48TD, 3560E-48TD-SD, 3560V2-24PS, 3560V2-24TS, 3560V2-24TS-SD, 3560V2-48PS, 3560V2-48TS, 3750E-24PD, 3750E-24TD, 3750E-48PD, 3750E-48PD-F, 3750E-48TD; Redundant Power System 2300
Input Voltage Range
AC 115 - 240 V
Frequency Required
50 - 60 Hz
Input Connectors
Power IEC 60320 C13
Power Capacity
1150 Watt
FCC Class A certified, BSMI, CISPR 22 Class A, GOST, CISPR 24, NOM, VCCI Class A ITE, EN55024, EN55022 Class A, AS/NZS 60950-1, CCC, FCC Part 15, MIC, UL 60950-1, IEC 60950-1, EN 60950-1
-5 °C
45 °C
10 - 85%
15.2 cm
37.9 cm
4.2 cm
2.6 kg
Cisco Catalyst 3560E-24PD, 3560E-24TD, 3560E-48PD, 3560E-48PD-F, 3560E-48TD, 3560E-48TD-SD, 3560V2-24PS, 3560V2-24TS, 3560V2-24TS-SD, 3560V2-48PS, 3560V2-48TS, 3750E-24PD, 3750E-24TD, 3750E-48PD, 3750E-48PD-F, 3750E-48TD ¦ Cisco Redundant Power System 2300
