Cisco Power Cord, 250VAC 10A BS1363 Plug (13 A fuse), UK
Quicklinx: 8X8RWS00 Mfr#: CAB-9K10A-UK
Length: 2.5m
11 In Stock
£14.76 ex VAT
£17.71 inc VAT
Cisco pays special attention to its network accessories which are the foundation stone of the whole network system. Cisco cables, adapters and other accessories will never let you down and you can always rely on the superior quality and outstanding reliability. Cisco has a wide range of network cables that will fit even the most extraordinary demands.
  • Robust compatibility
    Designed specifically for PC use, this power cable ensures seamless connectivity and power supply to your computing devices.
  • Durable design
    Rated for AC 250 V, the cable is built to withstand the demands of daily use, providing a reliable power connection to your equipment.
Cisco - power cable - IEC 60320 C15 to BS 1363A - 2.5 m
Power cable
Length
2.5 m
United Kingdom
Connector
Power IEC 60320 C15
Connector (Second End)
Power BS 1363A - male
Rated Voltage
AC 250 V
MDS 9020, 9124, 9134, 9222i; Nexus 2148T, 5020, 93108TC-EX, 93180YC-FX, 9336C-FX2, 9372PX-E; UCS SmartPlay Select C3260
Power cable
Rated Voltage
AC 250 V
Length
2.5 m
United Kingdom
Connector
Power IEC 60320 C15
Cisco MDS 9020 Fabric Switch, 9124 Multilayer Fabric Switch, 9134 Multilayer Fabric Switch, 9222i Multiservice Modular Switch , Cisco Nexus 2148T Fabric Extender, 5020, 93108TC-EX, 93180YC-FX, 9336C-FX2, 9372PX-E , Cisco UCS SmartPlay Select C3260 Basic, SmartPlay Select C3260 Basic Plus, SmartPlay Select C3260 Entry, SmartPlay Select C3260 Entry Plus, SmartPlay Select C3260 Performance, SmartPlay Select C3260 Performance Plus, SmartPlay Select C3260 Seed, SmartPlay Select C3260 Value
Length: 2.5m
Brand: Cisco
