Cisco pays special attention to its network accessories which are the foundation stone of the whole network system. Cisco cables, adapters and other accessories will never let you down and you can always rely on the superior quality and outstanding reliability. Cisco has a wide range of network cables that will fit even the most extraordinary demands.
Robust compatibility
Designed specifically for PC use, this power cable ensures seamless connectivity and performance, making it an essential accessory for your computing needs. -
High-quality construction
Featuring a power IEC 60320 C15 connector on one end and a power BS 1363 connector on the other, this cable is built for durability and reliability, capable of handling AC 250 V with ease.
 - Cisco - power cable - IEC 60320 C15 to BS 1363 - 2.44 m
 - Power cable
- Length
 - 2.44 m
- Localisation
 - United Kingdom
- Connector
 - Power IEC 60320 C15
- Connector (Second End)
 - Power BS 1363 - male
- Rated Voltage
 - AC 250 V
- Designed For
 - Catalyst 3850-24P-E, 3850-24P-L, 3850-24P-S, 3850-24PW-S, 3850-24T-E, 3850-24T-L, 3850-24T-S, 3850-48F-E, 3850-48F-L, 3850-48F-S, 3850-48P-E, 3850-48P-L, 3850-48P-S, 3850-48PW-S, 3850-48T-E, 3850-48T-L, 3850-48T-S, 9200L, 9300L
 - Power cable
- Rated Voltage
 - AC 250 V
- Length
 - 2.44 m
- Localisation
 - United Kingdom
- Connector
- Designed For
 - Cisco Catalyst 3850-24P-E, 3850-24P-L, 3850-24P-S, 3850-24PW-S, 3850-24T-E, 3850-24T-L, 3850-24T-S, 3850-48F-E, 3850-48F-L, 3850-48F-S, 3850-48P-E, 3850-48P-L, 3850-48P-S, 3850-48PW-S, 3850-48T-E, 3850-48T-L, 3850-48T-S, 9200L, 9300L
