Cisco - Power adapter - AC 100/240 V - for Aironet 702i Controller-based, 702i Standalone, 702W
Efficient compatibility
Designed specifically for PC use, this power adapter ensures seamless compatibility and efficient power delivery to your devices. -
Optimal power management
With a voltage provision of 48 V and the ability to operate on a wide range of input voltages (AC 100 / 240 V), this adapter is engineered for optimal power management and efficiency. -
Versatile design
The external form factor of the power adapter makes it a versatile addition to your tech toolkit, allowing for easy Plug-and-Play functionality across various setups.
- Cisco - power adapter
- Power adapter - external
- Input Voltage
- AC 100/240 V
- Output Voltage
- 48 V
- Designed For
- Aironet 702i Controller-based, 702i Standalone, 702W
- Input Voltage
- AC 100/240 V
- Frequency Required
- 50/60 Hz
- Output Voltage
- 48 V
- Designed For
- Cisco Aironet 702i Controller-based, 702i Standalone, 702W
