Cisco OneX Converter Module
Quicklinx: 9XR3WS00 Mfr#: CVR-X2-SFP10G=
Type: Modules
£124.05 ex VAT
£148.86 inc VAT
The Cisco OneX Converter Module offers investment protection for 10 Gigabit Ethernet X2 ports of Cisco switches by enabling migration from X2 to Small Form-Factor Pluggable Plus form factor without having to upgrade the switches or modules.
The OneX Converter Module converts a 10 Gigabit Ethernet X2 port into a 10 Gigabit Ethernet SFP+ port. With the OneX Converter Module, customers have the flexibility to use the 10 Gigabit X2 interface port of a switch with X2 modules or SFP+ modules. This flexibility is critical when the specific type of interface is not available in one or the other form factor or when customers want to use the same form factor for interfaces across multiple platforms deployed in their network.
  • Efficient connectivity
    The Cisco OneX Converter Module offers wired connectivity technology, ensuring stable and efficient network connections for demanding data environments.
  • High-speed data transfer
    With a data transfer rate of 10 Gbps, this module supports high-volume data traffic, facilitating swift and reliable data exchange across the network.
  • Versatile networking
    Designed to support Ethernet 10GBase-X, the module is versatile for various networking setups, making it a suitable choice for diverse operational needs.
Cisco OneX Converter Module - X2 transceiver module - 10GbE
Plug-in module
Cabling Type
10GBase-X
Data Transfer Rate
10 Gbps
10GbE
4.2 cm x 9.8 cm x 1.9 cm
300 g
90 days warranty
Catalyst 3560E-12D, 3560E-12SD-E, 3560E-12SD-S, 3560E-24PD, 3560E-24TD, 3560E-48PD, 3560E-48PD-F, 3560E-48TD, 3560E-48TD-SD, 3750E-24PD, 3750E-24TD, 3750E-48PD, 3750E-48PD-F, 3750E-48TD
Plug-in module
Wired
Cabling Type
10GBase-X
10GbE
Data Transfer Rate
10 Gbps
Expansion Slots
1 (total) / 1 (free) x SFP+
Compatible Slots
1 x X2
4.2 cm
9.8 cm
1.9 cm
300 g
Limited warranty - 90 days
Cisco Catalyst 3560E-12D, 3560E-12SD-E, 3560E-12SD-S, 3560E-24PD, 3560E-24TD, 3560E-48PD, 3560E-48PD-F, 3560E-48TD, 3560E-48TD-SD, 3750E-24PD, 3750E-24TD, 3750E-48PD, 3750E-48PD-F, 3750E-48TD
Type: Modules
Brand: Cisco
