Cisco Nexus 2248TP-E Fabric Extender Expansion Module
Quicklinx: CD6CWS00 Mfr#: N2K-C2248TP-E
Wired / Wireless: Wired
Protocol: Fast Ethernet, Gigabit Ethernet
Form Factor: Rack-mountable
Compatibility: PC
Type: Expansion module
£7,692.96 ex VAT
£9,231.55 inc VAT
The Cisco Nexus 2248TP-E Fabric Extender is a 1 Gigabit Ethernet fabric extender with enhancements that target workloads such as large-volume databases, distributed storage, and video editing. The Cisco Nexus 2248TP-E supports 48 100/1000BASE-T host facing ports and four 10 Gigabit Ethernet fabric interfaces.
  • Robust compatibility
    Designed to seamlessly integrate with PC systems, the Cisco Nexus 2248TP-E Fabric Extender offers a versatile solution for expanding network infrastructure.
  • Comprehensive connectivity
    With 48 RJ-45 connectors supporting 1000Base-T, this expansion module ensures ample connectivity options for Gigabit Ethernet, facilitating high-speed data transfer and efficient network operations.
  • Advanced networking features
    Equipped with features like Access Control List (ACL) support, Quality of Service (QoS), and VLAN support, the device enhances network management, security, and performance.
  • Durable design
    Adhering to a wide range of compliance standards including CISPR, EN, and IEEE, the Cisco Nexus 2248TP-E Fabric Extender is built to withstand the rigors of intense operating environments.
  • Efficient temperature management
    Operating efficiently within a temperature range of 0°C to 40°C and designed to handle humidity levels from 5 to 95% (non-condensing), ensuring reliability in various environmental conditions.
Cisco Nexus 2248TP-E Fabric Extender - expansion module - Gigabit Ethernet x 48 + 10 Gigabit SFP+ x 4
Expansion module
Rack-mountable
Ports
43.94 cm x 44.96 cm x 4.37 cm
8 kg
Cabling Type
Ethernet 100Base-TX, Ethernet 1000Base-T
Auxiliary Ports
4 x SFP+ (uplink)
100Mb LAN, 1GbE
Performance
Forwarding performance (full duplex): 80 Gbps , Forwarding performance: 176 Gbps , Forwarding performance: 131 Mpps
ACL entries: 256 , Policies: 64
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ae, IEEE 802.3an
1-year warranty
Nexus 5010, 5020, 5548, 5548P, 5548UP, 5596T, 5596UP, 6001, 6001P, 6001T, 6004, 6004 24, 6004EF, 7004, 7009, 7010, 7700, 7700 18, 7700 18-Slot, 7700 6, 7700 6-Slot, 7706, 7710
Expansion module
Rack-mountable
Ports
Wired
Cabling Type
Auxiliary Ports
4 x SFP+ (uplink)
Performance
Remote Management Protocol
SNMP 1, SNMP 2, RMON, SNMP 3, CLI
Status Indicators
Port status, power, system, module locator, fan
Flow control, full duplex capability, auto-negotiation, VLAN support, Cisco Gigabit EtherChannel, Syslog support, WRR queuing, STP support, ACL support, QoS, Jumbo Frames support, MIB, CoS, tagged VLAN, vPC technology, hot swappable power supply
Expansion Slots
4 (total) / 4 (free) x SFP+
48 x 1000Base-T - RJ-45
CISPR 22 Class A, CISPR 24, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class A, EN50082-1, EN 61000-6-1, AS/NZS 60950-1, ICES-003 Class A, FCC CFR47 Part 15, UL 60950-1, IEC 60950-1, EN 60950-1, RoHS, CSA C22.2 No. 60950-1, Directive 2004/108/EC, Directive 2006/95/EC, VCCI Class A, CNS 13438(95) Class A, KN22 Class A, EN 300 386, GB 4943.1-2011
Power supply - hot-plug / redundant - plug-in module
43.94 cm
44.96 cm
4.37 cm
8 kg
Limited warranty - advance parts replacement - 1 year
5 - 95% (non-condensing)
Cisco Nexus 5010, 5010 OSM version, 5010 Solutions Kit 8G FC Unified Fabric, 5020, 5020 IBM OSM version, 5020 Solutions Kit 8G FC Unified Fabric, 5548 Storage Solutions Bundle, 5548P, 5548UP, 5548UP in N5548UP-N2K Bundle, 5548UP Storage Solutions Bundle, 5596T, 5596UP, 5596UP Storage Solutions Bundle, 6001, 6001P, 6001T, 6004, 6004 24 x 40GE Ports/FCoE Bundle, 6004EF, 7004 Bundle, 7009, 7010, 7010 Bundle, 7700 18 Slot Chassis, 7700 18-Slot Switch 220 Gbps/Slot Fabric Module, 7700 6 Slot Chassis, 7700 6-Slot Switch 220 Gbps/Slot Fabric Module, 7700 Switches 10-Slot Chassis, 7700 Switches 10-Slot Switch 220 Gbps/Slot Fabric Module, 7706, 7710, 7710 Bundle
CD6C Cisco 10GBASE-CU SFP+ CABLE 5 METER In Stock £116.15
CD6C Cisco 10GBASE-CU SFP+ Cable 1 Meter In Stock £77.35
CD6C Cisco Power Cord, 250VAC 10A BS1363 Plug (13 A fuse), UK In Stock £14.27
CD6C Cisco SFP+ Copper Twinax Cable - SFP+ - SFP+ - 3m In Stock £63.36
CD6C Cisco SFP+ Copper Twinax Cable 2m - Brown In Stock £103.75
Protocol: Gigabit Ethernet
Compatibility: PC
Brand: Cisco
Price Range Ex VAT: £1500+
