Cisco StackWise stacking upgrade kit - Network stacking module - for Catalyst 3650-24, 3650-48
Enhanced connectivity
The StackWise stacking upgrade kit is designed to seamlessly integrate with your existing Cisco switch, offering a plug-in module form factor for easy installation. Its compatibility with PC systems ensures a smooth connection interface for all users. -
High-speed performance
Featuring Cisco StackWise-160 technology, this network stacking module provides an impressive bandwidth of 160 Gbps. This high-speed performance facilitates efficient data transfer and communication between networked devices, enhancing overall network efficiency. -
Durable design
With an external form factor and a 50 cm stacking cable, the upgrade kit is built for durability and long-term use. The cable's length and type are specifically designed to support the demands of stacking connections, ensuring reliable performance.
- Cisco StackWise stacking upgrade kit - network stacking module
- Form Factor
- Plug-in module
- 110 g
- Performance
- Bandwidth: 160 Gbps
- Designed For
- Catalyst 3650-24, 3650-48
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Performance
- Cisco StackWise-160 technology
- 1 x stack port
- Cables Included
- 1 x stacking cable (external) - 50 cm
- 110 g
- Designed For
- Cisco Catalyst 3650-24PD-E, 3650-24PD-L, 3650-24PD-S, 3650-24PS-E, 3650-24PS-L, 3650-24PS-S, 3650-24PWD-S, 3650-24PWS-S, 3650-24TD-E, 3650-24TD-L, 3650-24TD-S, 3650-24TS-E, 3650-24TS-L, 3650-24TS-S, 3650-48FD-E, 3650-48FD-L, 3650-48FD-S, 3650-48FQ-E, 3650-48FQ-L, 3650-48FQ-S, 3650-48FS-E, 3650-48FS-L, 3650-48FS-S, 3650-48FWD-S, 3650-48FWQ-S, 3650-48FWS-S, 3650-48PD-E, 3650-48PD-L, 3650-48PD-S, 3650-48PQ-E, 3650-48PQ-L, 3650-48PQ-S, 3650-48PS-E, 3650-48PS-L, 3650-48PS-S, 3650-48TD-E, 3650-48TD-L, 3650-48TD-S, 3650-48TQ-E, 3650-48TQ-L, 3650-48TQ-S, 3650-48TS-E, 3650-48TS-L, 3650-48TS-S
