Cisco Network Interface Expansion Module Gigabit Ethernet
Quicklinx: CN1NWS00 Mfr#: NIM-ES2-4=
Wired / Wireless: Wired
Protocol: Gigabit Ethernet, Fast Ethernet, Ethernet
Compatibility: PC
Type: Expansion module
£344.53 ex VAT
£413.43 inc VAT
The Cisco 4-Ports Layer 2 Gigabit EtherSwitch network interface modules switch modules to which you can connect Cisco IP phones, Cisco wireless access point workstations, and other network devices such as video devices, routers, switches, and other network switch modules.
  • Versatile connectivity
    With support for Ethernet 1000Base-T, Ethernet 100Base-TX, and Ethernet 10Base-T, the Cisco Network Interface Module ensures compatibility across a wide range of network infrastructures, making it an ideal solution for businesses looking to maintain robust connectivity.
  • High-speed performance
    Featuring a data transfer rate of 1 Gbps and support for auto-negotiation, full duplex capability, and half duplex mode, this expansion module is designed to optimize network performance and efficiency.
  • Advanced networking features
    Equipped with layer 2 switching capabilities and compliant with IEEE 802.3, IEEE 802.3ab, and IEEE 802.3u standards, the module enhances network management and reliability.
Cisco Network Interface Module - expansion module - Gigabit Ethernet x 4
Expansion module
Plug-in module
Ports
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, 1GbE
Data Transfer Rate
1 Gbps
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
Cisco IOS XE 3.15S
Cisco 4451-X, 4451-X Application Experience, 4451-X Integrated Services Router, 4451-X Integrated Services Router Security Bundle, 4451-X Integrated Services Router Voice and Video Bundle, 4451-X Integrated Services Router Voice Security Bundle
Expansion module
Plug-in module
Ports
Wired
Cabling Type
Data Transfer Rate
1 Gbps
Full duplex capability, Layer 2 switching, auto-negotiation, half duplex mode
4 x 1000Base-T - RJ-45
Cisco IOS XE 3.15S
Protocol: Fast Ethernet
Protocol: Ethernet
Compatibility: PC
Brand: Cisco
