Cisco ME 3400 SWITCH - 24 10/100 + 2 SFP AC PS
Quicklinx: 6D3CWS00 Mfr#: ME-3400-24TS-A
With service provider-friendly hardware and mission-specific software, the Cisco ME 3400 Series is the first access switch family optimized for both the Ethernet-to-the-home (ETTH) triple-play services and Ethernet-to-the-business (ETTB) VPN services. It provides the most complete security solution for Metro Ethernet access that covers subscriber, switch, and network protection. The Cisco ME 3400 Series supports multiple software images to provide a "pay-as-you-grow" deployment model. With service breadth spanning triple-play and Layer 2 and Layer 3 VPN services, reduced total cost of ownership (TCO) and operating expenses (OpEx) can be achieved from a single ETTH + ETTB access solution.
  • Robust connectivity
    Equipped with 24 10/100 ports plus 2 SFP (mini-GBIC) slots, this Cisco ME 3400-24TS switch ensures versatile connectivity options for a wide range of networking needs, making it a suitable solution for growing businesses.
  • Advanced layer 3 switching
    Offering comprehensive layer 3 switching capabilities, including support for routing protocols like BGP-4, EIGRP, OSPF, and RIP, the Cisco ME 3400-24TS facilitates efficient network traffic management and routing, ensuring reliable inter-network communication.
  • Efficient network management
    With support for SNMP, RMON, and Telnet, this switch allows for easy monitoring and management of network performance, helping to minimize downtime and maintain optimal network efficiency.
Cisco ME 3400-24TS - switch - 24 ports - Managed
Switch - 24 ports - L3 - Managed
Enclosure Type
1U
Subtype
Fast Ethernet
Ports
24 x 10/100 + 2 x SFP
MAC Address Table Size
8K entries
Routing Protocol
OSPF, BGP-4, RIP-1, RIP-2, EIGRP, PIM-SM, static IP routing, PIM-DM
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c
Layer 3 switching, Layer 2 switching, trunking, VLAN support
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s
44.5 cm x 24.2 cm x 4.4 cm
2.9 kg
Enclosure Type
Desktop 1U
Subtype
Fast Ethernet
Ports
8K entries
Routing Protocol
RAM
128 MB
Flash Memory
32 MB Flash
Status Indicators
Link OK, status, link/activity
1 x console RJ-45 management , 24 x 100Base-TX RJ-45 , 2 x SFP (mini-GBIC)
Internal power supply
30 watt
FCC Class A certified, CISPR 22 Class A, NOM, VCCI-I, EN55024, EN55022 Class A, UL 60950 Third Edition, FCC Part 15, MIC, AS/NZS 3548, CSA 22.2 No. 950 Third Edition
44.5 cm
24.2 cm
4.4 cm
2.9 kg
50 °C
5 - 95%
