The Cisco 4000 family Integrated Services Router (ISR) revolutionizes WAN communications in the enterprise branch. With new levels of built-in intelligent network capabilities and convergence, it specifically addresses the growing need for application-aware networking in distributed enterprise sites. These locations tend to have lean IT resources. But they often also have a growing need for direct communication with both private data centers and public clouds across diverse links, including Multiprotocol Label Switching (MPLS) VPNs and the Internet.
Cisco Intelligent WAN (IWAN)
Cisco IWAN is a set of intelligent software services that allow you to reliably and securely connect users, devices, and branch office locations across a diverse set of WAN transport links. IWAN-enabled routers like the ISR 4000 dynamically route traffic across the "best" link based on up-to-the-minute application and network conditions for great application experiences. You get tight control over application performance, bandwidth usage, data privacy, and availability of your WAN links - control that you need as your branches conduct greater volumes of mission-critical business. -
Cisco converged branch infrastructure
The Cisco 4000 Series ISRs consolidate many must-have IT functions, including network, compute, and storage resources. The high-performance, integrated routers run multiple concurrent IWAN services, including encryption, traffic management, and WAN optimization, without slowing your data throughput. And you can activate services on demand through a simple licensing change.
- Cisco Integrated Services Router 4331 - router - rack-mountable
- Router
- Enclosure Type
- Rack-mountable - modular - 1U
- WAN Ports Qty
- 3
- Data Link Protocol
- Performance
- Aggregate throughput: 100 Mbps
- IPSec, PPPoE, DHCP
- Routing Protocol
- OSPF, IS-IS, RIP-1, RIP-2, BGP, EIGRP, DVMRP, PIM-SM, IGMPv3, GRE, PIM-SSM, static IPv4 routing, static IPv6 routing, policy-based routing (PBR), IPv4-to-IPv6 Multicast
- Remote Management Protocol
- SNMP, RMON
- VPN support, VLAN support, Syslog support, IPv6 support, CBWFQ, WRED, wall mountable, ACL support, QoS, RADIUS support, NetFlow, IPFIX
- IEEE 802.3, IEEE 802.1Q, IEEE 802.3ah, IEEE 802.1ag, ANSI T1.101, ITU-T G.823, ITU-T G.824
- Power
- AC 120/230 V (50/60 Hz)
- 43.815 cm x 43.815 cm x 4.455 cm
- 5 kg
- 90 days warranty
- Router
- Enclosure Type
- Connectivity Technology
- Wired
- Performance
- Routing Protocol
- SNMP, RMON
- IEEE 802.3, IEEE 802.1Q, IEEE 802.3ah, IEEE 802.1ag, ANSI T1.101, ITU-T G.823, ITU-T G.824, CISPR 22 Class A, CISPR 24, EN55024, EN 55022 Class A, EN50082-1, AS/NZS 60950-1, ICES-003 Class A, CS-03, R&TTE, FCC CFR47 Part 15, UL 60950-1, IEC 60950-1, EN 60950-1, AS/NZS 3548 Class A, GB 4943, VCCI V-3, EN 61000, KN22, KN24, CNS 13438, EN 300 386, CAN/CSA-C22.2 No. 60950-1
- RAM
- 4 GB (installed) / 16 GB (max) - DDR3 SDRAM
- Flash Memory
- WAN / LAN: 2 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , Serial: 1 x console - RJ-45 , Management: 1 x console - mini-USB Type B , Serial: 1 x auxiliary - RJ-45 , USB 2.0: 1 x 4 pin USB Type A , 2 x SFP (mini-GBIC) , Management: 1 x RJ-45
- Expansion Slots
- 2 (total) / 2 (free) x NIM , 1 (total) / 1 (free) x ISC , 1 (total) / 1 (free) x Enhanced Service Module (SM-X) , 2 (total) / 0 (free) x DIMM 240-pin
- Power Device
- Internal power supply - 250 watt
- Installed Qty
- 1 (installed) / 1 (max)
- Voltage Required
- Rack Mounting Kit
- Included
- OS Provided
- Cisco IOS IP Base
- 43.815 cm
- 43.815 cm
- 4.455 cm
- 5 kg
- Limited warranty - advance parts replacement - 90 days - response time: 10 days
- 0 °C
- 40 °C
- 5 - 85%
Accessories (1)
Get the most from your Router
Cisco 1000BASE-T SFP Transceiver | In Stock | £188.66 |
Other bundles (3)
Cisco AC Power Cord (UK), C13, BS 1363, 2.5m | In Stock | £35.26 |
Cisco AC Power Cord | In Stock | £40.90 |
Cisco Connectors/Cabinet Power Cord 250 VAC | In Stock | £20.17 |
