Cisco ISR 4321 Router GigE Rack Mountable
Quicklinx: BZ2CWS00 Mfr#: ISR4321/K9
£1,586.00 ex VAT
£1,903.20 inc VAT
The Cisco 4000 family Integrated Services Router (ISR) revolutionizes WAN communications in the enterprise branch. With amazing levels of built-in intelligent network capabilities and convergence, it specifically addresses the growing need for application-aware networking in distributed enterprise sites. These locations tend to have lean IT resources. But they often also have a growing need for direct communication with both private data centers and public clouds across diverse links, including Multiprotocol Label Switching (MPLS) VPNs and the Internet. The Cisco 4000 series ISRs consolidate many must-have IT functions, including network, compute, and storage resources. The high-performance, integrated routers run multiple concurrent IWAN services without slowing your data throughput.
Cisco ISR 4321 features modular network interfaces with diverse connection options for load-balancing and network resiliency and modular interfaces with online removal and insertion (OIR) for module upgrades without network disruption.
  • High performance
    Cisco ISR 4321 features a distributed multicore architecture with internal services plane.
  • Lower WAN expenditures
    Embedded IWAN solution is designed for creating lower-cost, business-class Internet connections.
  • Superior and secure user application experiences
    Secure boot feature performs hardware-based authentication of the boot loader software to prevent malicious or unintended software from booting on the system. Code signing verifies digital signatures of executables prior to loading to prevent execution of altered or corrupted code. Hardware authentication protects against hardware counterfeiting by using an on-board tamper-proof silicon, including field replaceable modules. If authentication fails, the module is not allowed to boot.
  • IT consolidation, space savings, and improved total cost of ownership (TCO)
    Single converged branch platform integrates routing, switching, virtual server, storage, security, unified communications, WAN optimization, and performance management tools.
  • Business continuity and increased resiliency
Cisco Integrated Services Router 4321 - router - rack-mountable
Router
Enclosure Type
Rack-mountable - modular - 1U
WAN Ports Qty
2
Performance
Aggregate throughput: 50 Mbps
Network / Transport Protocol
IPSec, PPPoE, DHCP
Routing Protocol
OSPF, IS-IS, RIP-1, RIP-2, BGP, EIGRP, DVMRP, PIM-SM, IGMPv3, GRE, PIM-SSM, static IPv4 routing, static IPv6 routing, policy-based routing (PBR), IPv4-to-IPv6 Multicast
Remote Management Protocol
SNMP, RMON
VPN support, VLAN support, Syslog support, IPv6 support, CBWFQ, WRED, wall mountable, ACL support, QoS, RADIUS support, NetFlow, IPFIX
IEEE 802.3, IEEE 802.1Q, IEEE 802.3ah, IEEE 802.1ag, ANSI T1.101, ITU-T G.823, ITU-T G.824
36.957 cm x 29.464 cm x 4.455 cm
3.5 kg
90 days warranty
Router
Enclosure Type
Wired
Performance
IPSec, PPPoE, DHCP
Routing Protocol
SNMP, RMON
IEEE 802.3, IEEE 802.1Q, IEEE 802.3ah, IEEE 802.1ag, ANSI T1.101, ITU-T G.823, ITU-T G.824, CISPR 22 Class A, CISPR 24, EN55024, EN55022 Class A, EN50082-1, AS/NZS 60950-1, ICES-003 Class A, CS-03, R&TTE, FCC CFR47 Part 15, UL 60950-1, IEC 60950-1, EN 60950-1, AS/NZS 3548 Class A, GB 4943, VCCI V-3, EN 61000, KN22, KN24, CNS 13438, EN 300 386, CAN/CSA-C22.2 No. 60950-1
RAM
4 GB (installed) / 8 GB (max) - DDR3 SDRAM
Flash Memory
WAN / LAN: 2 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , Serial: 1 x console - RJ-45 , Management: 1 x console - mini-USB Type B , Serial: 1 x auxiliary - RJ-45 , USB 2.0: 1 x 4 pin USB Type A , 1 x SFP (mini-GBIC) , Management: 1 x RJ-45
Expansion Slots
2 (total) / 2 (free) x NIM , 1 (total) / 1 (free) x ISC , 1 (total) / 0 (free) x DIMM 240-pin
External power adapter
Rack Mounting Kit
Included
OS Provided
Cisco IOS IP Base
36.957 cm
29.464 cm
4.455 cm
3.5 kg
Limited warranty - advance parts replacement - 90 days - response time: 10 days
5 - 85%
BZ2C C2G 2m USB 2.0 A/B Cable - Black In Stock £4.20
BZ2C C2G 5m USB 2.0 A/B Cable - Black In Stock £5.74
BZ2C Cisco Console Cable 6 ft with USB Type A and mini-B In Stock £80.43
Type: Router
Standards: Ethernet
Standards: Fast Ethernet
Standards: Gigabit Ethernet
Brand: Cisco
Price Range Ex VAT: £1500+
