Cisco ISR 1100 4 Ports DSL
Quicklinx: DXZRWS00 Mfr#: C1117-4P
More than 50 In Stock
£760.97 ex VAT
£913.16 inc VAT
  • PORT COUNT
    4-port managed Gigabit Ethernet switch (2 ports PoE capable with 1 port PoE+)
  • CONNECTIVITY
    VA-DSL (Annex A) WAN and WAN/SFP combo ports with integrated USB 3.0 AUX/console
  • SECURITY
    Multi-layer, robust security and high-performance VPNs encrypt all data from the WAN edge to the cloud
  • PERFORMANCE
    Business router designed for broadband network speeds while running secure, concurrent data, voice, video and wireless services
  • PEACE OF MIND
    1-year limited hardware warranty with 10-day advanced replacement
Cisco Integrated Services Router 1117 - router - DSL modem - desktop
Router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL2+, VDSL2+
WAN Ports Qty
2
Performance
Encryption throughput: 250 Mbps
Network / Transport Protocol
IPSec, PPPoE, DHCP, DNS, L2TPv3
Routing Protocol
OSPF, IS-IS, RIP-1, RIP-2, BGP, EIGRP, HSRP, DVMRP, VRRP, PIM-SM, static IP routing, IGMPv3, GRE, PIM-SSM, policy-based routing (PBR), MPLS, Bidirectional Forwarding Detection (BFD), RSVP
Remote Management Protocol
SNMP, RMON, CLI, TR-069
CBWFQ, WRED, ACL support, QoS, DMVPN, 2T2R MIMO technology, NetFlow, MRC, IPFIX, CSD, LISP, packet aggregation A-MPDU, packet aggregation A-MSDU, MIB II, AVC, AAA, DFS, ERSPAN, EEM
IEEE 802.3af, IEEE 802.11i, IEEE 802.3ah, IEEE 802.1ag, IEEE 802.3at, IEEE 802.11r, IEEE 802.11ac Wave 2
32.3 cm x 23 cm x 4.2 cm
2.59 kg
1-year warranty
Router - 4-port switch (integrated)
Enclosure Type
Desktop
Wired
Performance
Routing Protocol
Encryption Algorithm
DES, Triple DES, SHA, MD5, IKE, ECDSA, 128-bit AES, 256-bit AES, 1024-bit RSA, 2048-bit RSA, 256-bit SHA, 512-bit SHA, 748-bit RSA, 384-bit SHA
Authentication Method
RADIUS
IEEE 802.3af, IEEE 802.11i, IEEE 802.3ah, IEEE 802.1ag, IEEE 802.3at, IEEE 802.11r, IEEE 802.11ac Wave 2, CISPR 24, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, CB, EN 61000-6-1, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, EN 61000-4-5, EN 61000-4-11, FCC CFR47 Part 15, UL 60950-1 Second Edition, VCCI V-3, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, AS/NZS CISPR 22, CNS 13438, EN 301 489-7, EN 301 489-1, FCC CFR47 Part 22, FCC CFR47 Part 24, CAN/CSA C22.2 No. 60950-1 Second Edition, EN 300 386, EN 301 489-24, EN 301 908-1, EN 301 908-2, EN 301 511, EN 301 908-13
RAM
4 GB
Flash Memory
4 GB
Status Indicators
Status
Communications
DSL modem
ADSL2+, VDSL2+
Protocols & Specifications
ITU G.992.5 Annex M, ITU G.993.2, ITU G.992.3 Annex M
WAN: 1 x 1000Base-T/1000Base-X - RJ-45/SFP , LAN: 2 x 1000Base-T - RJ-45 , LAN: 1 x 1000Base-T (PoE+) - RJ-45 , LAN: 1 x 1000Base-T (PoE) - RJ-45 , USB 3.0: 1 x console , WAN: 1 x VDSL2 / ADSL2+
32.3 cm
23 cm
4.2 cm
2.59 kg
Limited warranty - advance parts replacement - 1 year - response time: 10 days
65 °C
5 - 95% (non-condensing)
Accessories (1)
Get the most from your Router
DXZR Cisco 1000BASE-T SFP Transceiver In Stock £191.66
Other bundles (1)
DXZR Cisco AC Power Cord In Stock £41.18
Type: Router
Standards: Gigabit Ethernet
Standards: Ethernet
Standards: Fast Ethernet
Brand: Cisco
Price Range Ex VAT: £750 - £1000
