Cisco Integrated Services Router combines WAN, comprehensive security, wired and wireless access in a single, high-performance platform.
PORT COUNT
4-port managed Gigabit Ethernet switch (2 ports PoE capable with 1 port PoE+) -
CONNECTIVITY
VA-DSL (Annex A) WAN and WAN/SFP combo ports with integrated USB 3.0 AUX/console -
SECURITY
Multi-layer, robust security and high-performance VPNs encrypt all data from the WAN edge to the cloud -
PERFORMANCE
Business router designed for broadband network speeds while running secure, concurrent data, voice, video and wireless services -
PEACE OF MIND
1-year limited hardware warranty with 10-day advanced replacement
- Cisco Integrated Services Router 1117 - router - DSL modem - desktop
- Router - DSL modem - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Digital Signaling Protocol
- ADSL2+, VDSL2+
- WAN Ports Qty
- 2
- Data Link Protocol
- Performance
- Encryption throughput: 250 Mbps
- IPSec, PPPoE, DHCP, DNS, L2TPv3
- Routing Protocol
- OSPF, IS-IS, RIP-1, RIP-2, BGP, EIGRP, HSRP, DVMRP, VRRP, PIM-SM, static IP routing, IGMPv3, GRE, PIM-SSM, policy-based routing (PBR), MPLS, Bidirectional Forwarding Detection (BFD), RSVP
- Remote Management Protocol
- SNMP, RMON, CLI, TR-069
- CBWFQ, WRED, ACL support, QoS, DMVPN, 2T2R MIMO technology, NetFlow, MRC, IPFIX, CSD, LISP, packet aggregation A-MPDU, packet aggregation A-MSDU, MIB II, AVC, AAA, DFS, ERSPAN, EEM
- IEEE 802.3af, IEEE 802.11i, IEEE 802.3ah, IEEE 802.1ag, IEEE 802.3at, IEEE 802.11r, IEEE 802.11ac Wave 2
- Power
- AC 120/230 V (50/60 Hz)
- 32.3 cm x 23 cm x 4.2 cm
- 2.59 kg
- 1-year warranty
- Router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wired
- Performance
- Routing Protocol
- Encryption Algorithm
- DES, Triple DES, SHA, MD5, IKE, ECDSA, 128-bit AES, 256-bit AES, 1024-bit RSA, 2048-bit RSA, 256-bit SHA, 512-bit SHA, 748-bit RSA, 384-bit SHA
- Authentication Method
- RADIUS
- IEEE 802.3af, IEEE 802.11i, IEEE 802.3ah, IEEE 802.1ag, IEEE 802.3at, IEEE 802.11r, IEEE 802.11ac Wave 2, CISPR 24, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, CB, EN 61000-6-1, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, EN 61000-4-5, EN 61000-4-11, FCC CFR47 Part 15, UL 60950-1 Second Edition, VCCI V-3, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, AS/NZS CISPR 22, CNS 13438, EN 301 489-7, EN 301 489-1, FCC CFR47 Part 22, FCC CFR47 Part 24, CAN/CSA C22.2 No. 60950-1 Second Edition, EN 300 386, EN 301 489-24, EN 301 908-1, EN 301 908-2, EN 301 511, EN 301 908-13
- RAM
- 4 GB
- Flash Memory
- 4 GB
- Status Indicators
- Status
Communications
- DSL modem
- ADSL2+, VDSL2+
- Protocols & Specifications
- ITU G.992.5 Annex M, ITU G.993.2, ITU G.992.3 Annex M
- WAN: 1 x 1000Base-T/1000Base-X - RJ-45/SFP , LAN: 2 x 1000Base-T - RJ-45 , LAN: 1 x 1000Base-T (PoE+) - RJ-45 , LAN: 1 x 1000Base-T (PoE) - RJ-45 , USB 3.0: 1 x console , WAN: 1 x VDSL2 / ADSL2+
- Voltage Required
- 32.3 cm
- 23 cm
- 4.2 cm
- 2.59 kg
- Limited warranty - advance parts replacement - 1 year - response time: 10 days
- 0 °C
- 65 °C
- 5 - 95% (non-condensing)
Accessories (1)
Get the most from your Router
Cisco 1000BASE-T SFP Transceiver | In Stock | £184.31 |
Other bundles (1)
Cisco AC Power Cord | In Stock | £40.15 |
