Cisco IP Phone 8865 - IP video phone - digital camera, Bluetooth interface
Quicklinx: F316WS00 Mfr#: CP-8865-K9=
Recommended Use: [N/A]
Connectivity: [N/A]
Earcover : [N/A]
£394.12 ex VAT
£472.94 inc VAT
The IP Phone 8865 combines an attractive ergonomic design with 720p HD video and wideband audio for crystal-clear voice communications, "always-on" reliability. Encrypted voice communications for enhanced security. And access to a comprehensive suite of unified communications features.
In addition, with Cisco Intelligent Proximity you can use your desk and mobile phones together when you are at your desk. During mobile calls you can move the audio path over to the 8865 for better acoustics. You then could share a conversation with a colleague who listens in. This capability gives you greater flexibility and a superior user experience when at your desk.
The 8865 comes standard with two USB ports so you can charge your personal mobile devices when at your desk and stay connected when away from your desk.
The IP Phone 8865 offers five programmable line keys. You can configure keys to support either multiple directory numbers or calling features such as speed dial. You can also boost productivity by handling multiple calls for each directory number using the multicall-per-line feature. Fixed-function keys give you one-touch access to applications, messaging, directory, as well as often-used calling features such as hold/resume, transfer, and conference. A five-way navigation cluster helps you transition through menus more easily. Backlit acoustic keys provide flexibility for audio path selection and switching.
  • LARGE DISPLAY
    5-inch high-resolution widescreen WVGA colour display with 720p HD two-way video and localised language support to meet the needs of global users
  • FIXED FUNCTION KEYS
    One-touch access to service, messaging, directory, hold/resume, transfer and conference features
  • FULLY PROGRAMMABLE
    Set up line keys to support either lines, such as directory numbers, or call features like speed dialling
  • OPTIMAL PERFORMANCE
    Class 4 PoE with a built-in Ethernet Gigabit switch for your PC connection; 802.11a/b/g/n/ac Wi-Fi compatible
  • PEACE OF MIND
    1-year limited hardware warranty
Cisco IP Phone 8865 - IP video phone - with digital camera, Bluetooth interface
Cordless Phone Standard
IEEE 802.11a/b/g/n/ac (Wi-Fi)
Main Features
Integrated Ethernet switch
VoIP Protocols
SIP, SDP
Voice Codecs
G.722, G.729a, G.711u, G.711a, iLBC, iSAC
Lines Supported
5 lines
Intercom
Speakerphone
Yes (digital duplex)
Call Services
Voice Mail, Caller ID, Call Waiting, Call Transfer, Call Hold, Message Waiting Capability
Display
LCD display - colour - Yes
Network Ports Qty
2 x Ethernet 10Base-T/100Base-TX/1000Base-T
Compatible Software
Cisco Unified Communications Manager 8.5.1 or later, Cisco Unified Communications Manager Express 10.0 or later
1.35 kg
Body Colour
Charcoal
IP video phone
Integrated Components
Digital camera, Bluetooth interface
1.35 kg
Body Colour
Charcoal
Body Material
ABS polycarbonate
Phone Features
Wireless Interface Provided
Bluetooth
Bluetooth Profiles
Hands-Free Profile (HFP), Phonebook Access Profile (PBAP)
Call Services
Key Expansion Module Max Qty
3
Dialer Type
Keypad
Dialer Location
Base
Conference Call Capability
Intercom
Speakerphone
Voice Recording
Programmable Buttons Qty
5
Indicators
New message indicator
Additional Functions
Call timer, Intercom
Additional Features
Music on hold
IP Telephony
Main Features
VoIP
VoIP Protocols
SIP, SDP
Voice Codecs
Video Codecs
H.264
Lines Supported
5 lines
Quality of Service
IEEE 802.1Q (VLAN), IEEE 802.1p
IP Address Assignment
DHCP, static
Security
128-bit WEP, 40 bit WEP, WPA, TKIP, WPA2, IEEE 802.1X, TLS
Power Over Ethernet (PoE) Support
Network Protocols
TFTP, UDP, Cisco Discovery Protocol (CDP), DNS, HTTPS, Link Layer Discovery Protocol (LLDP), SRTP, Link Layer Discovery Protocol - Media Endpoint Discovery (LLDP-MED), RTCP, RTP, GARP
Network Ports Qty
Compatible Software
Network Features
Class 4 PoE
Display
Display Location
Base
Diagonal Size
5"
Display Resolution
800 x 480 pixels
Colour Depth
24-bit (16.7 million colours)
Backlit
Phone Camera
Camera Resolution
1280 x 720
Headset jack / RJ-9 , 2 x USB / 4 PIN USB Type A , Audio line in/out / mini-phone 3.5mm , Electronic hook switch (EHS)
Hearing Aid Compatible
Placing / Mounting
Wall-mountable
Dimensions & Weight (Base)
25.734 cm
9.839 cm
22.878 cm
1.35 kg
Connectivity: [N/A]
Earcover : [N/A]
Brand: Cisco
