The IP Phone 8865 combines an attractive ergonomic design with 720p HD video and wideband audio for crystal-clear voice communications, "always-on" reliability. Encrypted voice communications for enhanced security. And access to a comprehensive suite of unified communications features.
In addition, with Cisco Intelligent Proximity you can use your desk and mobile phones together when you are at your desk. During mobile calls you can move the audio path over to the 8865 for better acoustics. You then could share a conversation with a colleague who listens in. This capability gives you greater flexibility and a superior user experience when at your desk.
The 8865 comes standard with two USB ports so you can charge your personal mobile devices when at your desk and stay connected when away from your desk.
The IP Phone 8865 offers five programmable line keys. You can configure keys to support either multiple directory numbers or calling features such as speed dial. You can also boost productivity by handling multiple calls for each directory number using the multicall-per-line feature. Fixed-function keys give you one-touch access to applications, messaging, directory, as well as often-used calling features such as hold/resume, transfer, and conference. A five-way navigation cluster helps you transition through menus more easily. Backlit acoustic keys provide flexibility for audio path selection and switching.
LARGE DISPLAY
5-inch high-resolution widescreen WVGA colour display with 720p HD two-way video and localised language support to meet the needs of global users -
FIXED FUNCTION KEYS
One-touch access to service, messaging, directory, hold/resume, transfer and conference features -
FULLY PROGRAMMABLE
Set up line keys to support either lines, such as directory numbers, or call features like speed dialling -
OPTIMAL PERFORMANCE
Class 4 PoE with a built-in Ethernet Gigabit switch for your PC connection; 802.11a/b/g/n/ac Wi-Fi compatible -
PEACE OF MIND
1-year limited hardware warranty
- Cisco IP Phone 8865 - IP video phone - with digital camera, Bluetooth interface
- Product Type
- Cordless Phone Standard
- IEEE 802.11a/b/g/n/ac (Wi-Fi)
- Main Features
- Integrated Ethernet switch
- VoIP Protocols
- SIP, SDP
- Voice Codecs
- G.722, G.729a, G.711u, G.711a, iLBC, iSAC
- Lines Supported
- 5 lines
- Intercom
- Speakerphone
- Yes (digital duplex)
- Call Services
- Voice Mail, Caller ID, Call Waiting, Call Transfer, Call Hold, Message Waiting Capability
- Display
- LCD display - colour - Yes
- Network Ports Qty
- 2 x Ethernet 10Base-T/100Base-TX/1000Base-T
- Compatible Software
- Cisco Unified Communications Manager 8.5.1 or later, Cisco Unified Communications Manager Express 10.0 or later
- 1.35 kg
- Body Colour
- Charcoal
- Product Type
- IP video phone
- Integrated Components
- Digital camera, Bluetooth interface
- 1.35 kg
- Body Colour
- Charcoal
- Body Material
- ABS polycarbonate
Phone Features
- Wireless Interface Provided
- Bluetooth
- Bluetooth Profiles
- Hands-Free Profile (HFP), Phonebook Access Profile (PBAP)
- Call Services
- Key Expansion Module Max Qty
- 3
- Dialer Type
- Keypad
- Dialer Location
- Base
- Conference Call Capability
- Intercom
- Speakerphone
- Voice Recording
- Programmable Buttons Qty
- 5
- Indicators
- New message indicator
- Additional Functions
- Call timer, Intercom
- Additional Features
- Music on hold
IP Telephony
- Main Features
- VoIP
- VoIP Protocols
- SIP, SDP
- Voice Codecs
- Video Codecs
- H.264
- Lines Supported
- 5 lines
- Quality of Service
- IEEE 802.1Q (VLAN), IEEE 802.1p
- IP Address Assignment
- DHCP, static
- Security
- 128-bit WEP, 40 bit WEP, WPA, TKIP, WPA2, IEEE 802.1X, TLS
- Power Over Ethernet (PoE) Support
- Network Protocols
- TFTP, UDP, Cisco Discovery Protocol (CDP), DNS, HTTPS, Link Layer Discovery Protocol (LLDP), SRTP, Link Layer Discovery Protocol - Media Endpoint Discovery (LLDP-MED), RTCP, RTP, GARP
- Network Ports Qty
- Network Features
- Class 4 PoE
Display
- Display Location
- Base
- Diagonal Size
- 5"
- Display Resolution
- 800 x 480 pixels
- Colour Depth
- 24-bit (16.7 million colours)
- Backlit
Phone Camera
- Camera Resolution
- 1280 x 720
- Connections
- Headset jack / RJ-9 , 2 x USB / 4 PIN USB Type A , Audio line in/out / mini-phone 3.5mm , Electronic hook switch (EHS)
- Hearing Aid Compatible
- Placing / Mounting
- Wall-mountable
Dimensions & Weight (Base)
- 25.734 cm
- 9.839 cm
- 22.878 cm
- 1.35 kg
