The Cisco IP Phone 8845 can help you increase personal productivity through powerful and easy-to-use user experiences. It combines an attractive new ergonomic design with 720p HD video and wideband audio for crystal-clear video and voice communications and "always-on" reliability. The 8845 encrypts video and voice communications for security, and offers access to a comprehensive suite of unified communications features.
In addition, Cisco Intelligent Proximity brings the worlds of desk and mobile together for you when you are using your mobile device at the desk for your work. You can move the audio path over to the 8845 during active mobile calls to take advantage of its superior audio acoustics. An example would be to share a conversation with a colleague who listens in. This capability gives you greater flexibility when at your desk.
The Cisco IP Phone 8845 offers five programmable line keys. You can configure keys to support either multiple directory numbers or call features such as speed dial. You can also boost productivity by handling multiple calls for each directory number, using the multicall-per-line feature. Fixed function keys give you one-touch access to applications, messaging, directory, as well as often-used calling features such as hold/resume, transfer, and conference. Backlit acoustic keys provide flexibility for audio path selection and switching.
High-definition video calls
Equipped with a digital camera that supports 1280 x 720 resolution, the Cisco IP Phone 8845 transforms business communications by providing high-quality, face-to-face video calls right from the desk. -
Crystal clear audio
Featuring a wide array of voice codecs including G.711a, G.711u, G.722, G.729a, iLBC, and iSAC, the Cisco IP Phone 8845 ensures every conversation is heard with exceptional clarity, whether it's through the handset, speakerphone, or a connected headset. -
Enhanced connectivity
With integrated Bluetooth interface and support for both Hands-Free Profile (HFP) and Phonebook Access Profile (PBAP), users can seamlessly connect their mobile devices for a unified communication experience. -
Efficient call management
The phone boasts 5 programmable buttons, allowing for quick access to frequently used functions and services such as Call Forwarding, Call Hold, Call Transfer, and Voice Mail, enhancing productivity and user experience. -
Robust network features
Supporting advanced network protocols and services including Class 2 PoE, Cisco Discovery Protocol, and secure voice communication with TLS and SRTP, the Cisco IP Phone 8845 is designed to meet the demands of modern business environments.
- Cisco IP Phone 8845 - IP video phone - with digital camera, Bluetooth interface
- Product Type
- Compatible Platforms
- Cisco Business Edition 6000
- Main Features
- Multiple VoIP protocol support, integrated Ethernet switch
- VoIP Protocols
- SIP, SDP
- Voice Codecs
- G.722, G.729a, G.711u, G.711a, iLBC, iSAC
- Lines Supported
- 5 lines
- Intercom
- Speakerphone
- Yes (digital duplex)
- Call Services
- Voice Mail, Caller ID, Call Waiting, Call Forwarding, Call Transfer, Call Hold, Message Waiting Capability
- Display
- LCD display - colour - Yes
- Network Ports Qty
- 2 x Ethernet 10Base-T/100Base-TX/1000Base-T
- Compatible Software
- Cisco Unified Communications Manager 8.5.1 or later, Cisco Unified Communications Manager Express 10.0 or later
- 1.35 kg
- Body Colour
- Charcoal
- Product Type
- IP video phone
- Integrated Components
- Digital camera, Bluetooth interface
- 1.35 kg
- Body Colour
- Charcoal
- Body Material
- ABS polycarbonate
Phone Features
- Wireless Interface Provided
- Bluetooth
- Bluetooth Profiles
- Hands-Free Profile (HFP), Phonebook Access Profile (PBAP)
- Call Services
- Dialer Type
- Keypad
- Dialer Location
- Base
- Conference Call Capability
- Intercom
- Speakerphone
- Voice Recording
- Programmable Buttons Qty
- 5
- Indicators
- New message indicator
- Additional Functions
- Call timer, Intercom
- Additional Features
- Music on hold
IP Telephony
- Main Features
- VoIP
- VoIP Protocols
- SIP, SDP
- Voice Codecs
- Video Codecs
- H.264
- Lines Supported
- 5 lines
- Quality of Service
- IEEE 802.1Q (VLAN), IEEE 802.1p
- IP Address Assignment
- DHCP, static
- Security
- IEEE 802.1X, TLS
- Power Over Ethernet (PoE) Support
- Network Protocols
- TFTP, UDP, Cisco Discovery Protocol (CDP), DNS, HTTPS, Link Layer Discovery Protocol (LLDP), SRTP, Link Layer Discovery Protocol - Media Endpoint Discovery (LLDP-MED), RTCP, RTP, GARP
- Network Ports Qty
- Network Features
- Class 2 PoE
Display
- Display Location
- Base
- Diagonal Size
- 5"
- Display Resolution
- 800 x 480 pixels
- Colour Depth
- 24-bit (16.7 million colours)
- Backlit
Phone Camera
- Camera Resolution
- 1280 x 720
- Connections
- Headset jack / RJ-9 , Electronic hook switch (EHS)
- Hearing Aid Compatible
- Placing / Mounting
- Wall-mountable, table-top
Dimensions & Weight (Base)
- 25.734 cm
- 9.839 cm
- 22.878 cm
- 1.35 kg
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £8.56 |
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.92 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £10.60 |
