Cisco IP Phone 8845 IP Video Phone, Digital Camera, Bluetooth Inte
Quicklinx: CBKRWS00 Mfr#: CP-8845-K9=
£412.67 ex VAT
£495.20 inc VAT
The Cisco IP Phone 8845 can help you increase personal productivity through powerful and easy-to-use user experiences. It combines an attractive new ergonomic design with 720p HD video and wideband audio for crystal-clear video and voice communications and "always-on" reliability. The 8845 encrypts video and voice communications for security, and offers access to a comprehensive suite of unified communications features.
In addition, Cisco Intelligent Proximity brings the worlds of desk and mobile together for you when you are using your mobile device at the desk for your work. You can move the audio path over to the 8845 during active mobile calls to take advantage of its superior audio acoustics. An example would be to share a conversation with a colleague who listens in. This capability gives you greater flexibility when at your desk.
The Cisco IP Phone 8845 offers five programmable line keys. You can configure keys to support either multiple directory numbers or call features such as speed dial. You can also boost productivity by handling multiple calls for each directory number, using the multicall-per-line feature. Fixed function keys give you one-touch access to applications, messaging, directory, as well as often-used calling features such as hold/resume, transfer, and conference. Backlit acoustic keys provide flexibility for audio path selection and switching.
  • High-definition video calls
    Equipped with a digital camera that supports 1280 x 720 resolution, the Cisco IP Phone 8845 transforms business communications by providing high-quality, face-to-face video calls right from the desk.
  • Crystal clear audio
    Featuring a wide array of voice codecs including G.711a, G.711u, G.722, G.729a, iLBC, and iSAC, the Cisco IP Phone 8845 ensures every conversation is heard with exceptional clarity, whether it's through the handset, speakerphone, or a connected headset.
  • Enhanced connectivity
    With integrated Bluetooth interface and support for both Hands-Free Profile (HFP) and Phonebook Access Profile (PBAP), users can seamlessly connect their mobile devices for a unified communication experience.
  • Efficient call management
    The phone boasts 5 programmable buttons, allowing for quick access to frequently used functions and services such as Call Forwarding, Call Hold, Call Transfer, and Voice Mail, enhancing productivity and user experience.
  • Robust network features
    Supporting advanced network protocols and services including Class 2 PoE, Cisco Discovery Protocol, and secure voice communication with TLS and SRTP, the Cisco IP Phone 8845 is designed to meet the demands of modern business environments.
Cisco IP Phone 8845 - IP video phone - with digital camera, Bluetooth interface
Compatible Platforms
Cisco Business Edition 6000
Main Features
Multiple VoIP protocol support, integrated Ethernet switch
VoIP Protocols
SIP, SDP
Voice Codecs
G.722, G.729a, G.711u, G.711a, iLBC, iSAC
Lines Supported
5 lines
Intercom
Speakerphone
Yes (digital duplex)
Call Services
Voice Mail, Caller ID, Call Waiting, Call Forwarding, Call Transfer, Call Hold, Message Waiting Capability
Display
LCD display - colour - Yes
Network Ports Qty
2 x Ethernet 10Base-T/100Base-TX/1000Base-T
Compatible Software
Cisco Unified Communications Manager 8.5.1 or later, Cisco Unified Communications Manager Express 10.0 or later
1.35 kg
Body Colour
Charcoal
IP video phone
Integrated Components
Digital camera, Bluetooth interface
1.35 kg
Body Colour
Charcoal
Body Material
ABS polycarbonate
Phone Features
Wireless Interface Provided
Bluetooth
Bluetooth Profiles
Hands-Free Profile (HFP), Phonebook Access Profile (PBAP)
Call Services
Dialer Type
Keypad
Dialer Location
Base
Conference Call Capability
Intercom
Speakerphone
Voice Recording
Programmable Buttons Qty
5
Indicators
New message indicator
Additional Functions
Call timer, Intercom
Additional Features
Music on hold
IP Telephony
Main Features
VoIP
VoIP Protocols
SIP, SDP
Voice Codecs
Video Codecs
H.264
Lines Supported
5 lines
Quality of Service
IEEE 802.1Q (VLAN), IEEE 802.1p
IP Address Assignment
DHCP, static
Security
IEEE 802.1X, TLS
Power Over Ethernet (PoE) Support
Network Protocols
TFTP, UDP, Cisco Discovery Protocol (CDP), DNS, HTTPS, Link Layer Discovery Protocol (LLDP), SRTP, Link Layer Discovery Protocol - Media Endpoint Discovery (LLDP-MED), RTCP, RTP, GARP
Network Ports Qty
Compatible Software
Network Features
Class 2 PoE
Display
Display Location
Base
Diagonal Size
5"
Display Resolution
800 x 480 pixels
Colour Depth
24-bit (16.7 million colours)
Backlit
Phone Camera
Camera Resolution
1280 x 720
Headset jack / RJ-9 , Electronic hook switch (EHS)
Hearing Aid Compatible
Placing / Mounting
Wall-mountable, table-top
Dimensions & Weight (Base)
25.734 cm
9.839 cm
22.878 cm
1.35 kg
CBKR C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.68
CBKR C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £9.87
Brand: Cisco
