The Cisco IP Phone 8841 delivers mission-critical voice communications that are highly secure and easy to use. It offers wideband audio and a large, widescreen, high-resolution color display for menus and content. The 8841 is ideal for knowledge workers, administrative staff, and managers in mid-sized to large businesses. As a low-power device, it is both cost-effective and earth-friendly.
Increase productivity
Enjoy exceptional clarity in voice communications. The 8841 model offers high-quality, full-duplex, wideband (G. 22) audio with superior echo cancellation with support on a headset, the handset, or its speakerphone. Navigate menus more easily and recognize displayed content at a glance, under a variety of lighting conditions. The 8841 delivers a large, five-inch, high-resolution, widescreen VGA (800 x 480 pixel) backlit color display. Take advantage of a more intuitive user experience that includes a five-way navigation cluster and four context-sensitive soft keys to help guide your communications.
- Cisco IP Phone 8841 - VoIP phone
- Product Type
- VoIP phone
- Compatible Platforms
- Cisco Business Edition 6000
- Main Features
- Multiple VoIP protocol support, integrated Ethernet switch
- VoIP Protocols
- SIP, RTCP, RTP, SRTP, SDP
- Voice Codecs
- G.722, G.729a, G.711u, G.711a, iLBC, iSAC
- Lines Supported
- 5 lines
- Intercom
- Speakerphone
- Yes (digital duplex)
- Call Services
- Voice Mail, Caller ID, Call Waiting, Call Forwarding, Call Transfer, Call Hold, Message Waiting Capability
- Display
- LCD display - colour - Yes
- Network Ports Qty
- 2 x Ethernet 10Base-T/100Base-TX/1000Base-T
- Compatible Software
- Cisco Unified Communications Manager 8.5.1 or later, Cisco Hosted Collaboration Solution, Cisco Unified Communications Manager Express 10.0 or later
- 1-year warranty
- Product Type
- VoIP phone
- Body Material
- ABS plastic
Phone Features
- Call Services
- Dialer Type
- Keypad
- Dialer Location
- Base
- Conference Call Capability
- Intercom
- Speakerphone
- Menu Operation
- Programmable Buttons Qty
- 5
- Indicators
- Voice message waiting indicator, speakerphone indicator, headset
- Firmware Upgradable
- Additional Functions
- Call timer, Intercom
- Additional Features
- Music on hold, BLF status lamps
IP Telephony
- Main Features
- VoIP
- VoIP Protocols
- Voice Codecs
- Lines Supported
- 5 lines
- Quality of Service
- IEEE 802.1Q (VLAN), IEEE 802.1p
- Security
- IEEE 802.1X, TLS
- Power Over Ethernet (PoE) Support
- Network Protocols
- IP, TFTP, UDP, Cisco Discovery Protocol (CDP), HTTP, DNS, HTTPS, SRTP, Link Layer Discovery Protocol - Media Endpoint Discovery (LLDP-MED), RTCP, RTP
- Network Ports Qty
- Network Features
- Class 2 PoE
Display
- Display Location
- Base
- Diagonal Size
- 5"
- Display Resolution
- 800 x 480 pixels
- Colour Depth
- 24-bit (16.7 million colours)
- Backlit
- Display Languages
- Danish, Hebrew, Hungarian, Czech, Croatian, Slovenian, Thai, Slovak, Brazilian Portuguese, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Latvian, Lithuanian, Estonian, Serbian, Romanian, Catalan, Japanese, Chinese, Korean
- Connections
- Headset jack / RJ-9 , Electronic hook switch (EHS)
- Hearing Aid Compatible
- Placing / Mounting
- Wall-mountable, table mount
- ADA, HAC (Hearing Aid Compatible)
Dimensions & Weight (Base)
- 25.734 cm
- 4 cm
- 22.91 cm
- 1.17 kg
- Limited warranty - replacement - 1 year
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £8.56 |
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.71 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £14.87 |
Cisco Wall Mount Kit For IP Phone 8841, 8851, 8861 | In Stock | £46.56 |
Customer reviews
Write a review for the Cisco IP Phone 8841 VoIP here!
dsaf
Reviewed by Anonymous Review Posted 06/08/2019
dgvdsa
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
