Cisco IP Phone 8811 - VoIP
Quicklinx: C3F7WS00 Mfr#: CP-8811-K9=
Hurry, only 1 left in stock!
£260.69 ex VAT
£312.82 inc VAT
The Cisco IP Phone 8811 is a cost-effective, business-class collaboration endpoint that delivers high-fidelity, reliable, secure and scalable voice communications for midsize to large enterprise businesses.
With the Cisco IP Phone 8811, you can increase personal productivity through an engaging user experience that is both powerful and easy-to-use. The IP Phone 8811 combines an attractive ergonomic design with wideband audio for crystal clear voice communications, "always-on" reliability, encrypted voice communications to enhance security and access to a comprehensive suite of unified communications features from Cisco communication servers.
The Cisco IP Phone 8811 supports five programmable line keys. You can configure keys to support either multiple directory numbers or calling features such as speed dial. You can also boost productivity by handling multiple calls for each directory number, using the multicall-per-line feature. Fixed-function keys give you one-touch access to applications, messaging, directory, as well as often-used calling features such as hold/resume, transfer, and conference. Backlit acoustic keys provide flexibility for audio path selection and switching.
The Cisco IP Phone 8811 offers a 5-in. high-resolution (800 x 480) widescreen backlit grayscale display. Localized language support, including right-to-left on-screen text, meets the needs of global users.
The phone supports a built-in Gigabit Ethernet switch for your PC connection.
  • LARGE DISPLAY
    5-inch high-resolution widescreen greyscale display with localised language support to meet the needs of global users
  • FIXED FUNCTION KEYS
    One-touch access to service, messaging, directory, hold/resume, transfer and conference features
  • FULLY PROGRAMMABLE
    Set up line keys to support either lines, such as directory numbers, or call features like speed dialling
  • OPTIMAL PERFORMANCE
    Class 2 PoE with a built-in Ethernet Gigabit switch for your PC connection
  • PEACE OF MIND
    1-year limited hardware warranty
Cisco IP Phone 8811 - VoIP phone
VoIP phone
Compatible Platforms
Cisco Business Edition 6000
Main Features
Multiple VoIP protocol support, integrated Ethernet switch
VoIP Protocols
SIP, RTCP, RTP, SRTP, SDP
Voice Codecs
G.722, G.729a, G.711u, G.711a, iLBC, iSAC
Lines Supported
5 lines
Intercom
Speakerphone
Yes (digital duplex)
Call Services
Voice Mail, Caller ID, Call Waiting, Call Forwarding, Call Transfer, Call Hold, Message Waiting Capability
Display
LCD display - monochrome - Yes
Network Ports Qty
2 x Ethernet 10Base-T/100Base-TX/1000Base-T
Compatible Software
Cisco Unified Communications Manager 8.5.1 or later, Cisco Hosted Collaboration Solution, Cisco Unified Communications Manager Express 10.0 or later
1-year warranty
VoIP phone
Body Material
ABS plastic
Phone Features
Call Services
Dialer Type
Keypad
Dialer Location
Base
Conference Call Capability
Intercom
Speakerphone
Menu Operation
Programmable Buttons Qty
5
Indicators
Voice message waiting indicator, speakerphone indicator, headset
Firmware Upgradable
Additional Functions
Call timer, Intercom
Additional Features
Music on hold, BLF status lamps
IP Telephony
Main Features
VoIP
VoIP Protocols
Voice Codecs
Lines Supported
5 lines
Quality of Service
IEEE 802.1Q (VLAN), IEEE 802.1p
Security
IEEE 802.1X, TLS
Power Over Ethernet (PoE) Support
Network Protocols
IP, TFTP, UDP, Cisco Discovery Protocol (CDP), HTTP, DNS, HTTPS, SRTP, Link Layer Discovery Protocol - Media Endpoint Discovery (LLDP-MED), RTCP, RTP
Network Ports Qty
Compatible Software
Network Features
Class 2 PoE
Display
Display Location
Base
Diagonal Size
5"
Display Resolution
800 x 480 pixels
Backlit
Display Languages
Danish, Hebrew, Hungarian, Czech, Croatian, Slovenian, Thai, Slovak, Brazilian Portuguese, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Latvian, Lithuanian, Estonian, Serbian, Romanian, Catalan, Japanese, Chinese, Korean
Headset jack / RJ-9 , Electronic hook switch (EHS)
Hearing Aid Compatible
Placing / Mounting
Wall-mountable, table mount
ADA, HAC (Hearing Aid Compatible)
Dimensions & Weight (Base)
25.734 cm
4 cm
22.91 cm
1.17 kg
Limited warranty - replacement - 1 year
Brand: Cisco
