Deploy high-quality voice communications for your information workers, the administrative and managerial staff. The affordable Cisco IP Phone 7841 is full-featured and easy to use. Business calls are more efficient and productive, which fosters collaboration. The 7841 also supports wideband audio for superior voice quality and offers advanced IP communications features.
Versatile display options
The Cisco IP Phone 7841 features a 3.5-inch monochrome LCD display, offering clear and crisp visuals. With backlight support, it ensures readability in various lighting conditions. -
Comprehensive language support
This device breaks language barriers with an extensive array of display languages ranging from Arabic to Turkish, catering to a global workforce. -
Enhanced call management
Equipped with functionalities like call forwarding, call hold, call transfer, and more, it streamlines communication for efficient workflow. -
Robust connectivity
With two Ethernet ports supporting speeds up to 1000Base-T and Power over Ethernet (PoE) support, the Cisco IP Phone 7841 ensures reliable connectivity and easy installation. -
Advanced security features
The phone incorporates IEEE 802.1X security, safeguarding your communications and ensuring peace of mind.
- Cisco IP Phone 7841 - VoIP phone
- Product Type
- VoIP phone
- Compatible Platforms
- Cisco Business Edition 6000
- Main Features
- Multiple VoIP protocol support, integrated Ethernet switch
- VoIP Protocols
- SIP, SRTP
- Voice Codecs
- G.722, G.729ab, G.711u, G.711a, iLBC
- Lines Supported
- 4 lines
- Speakerphone
- Yes (digital duplex)
- Call Services
- Voice Mail, Caller ID, Call Waiting, Call Forwarding, Call Transfer, Call Hold, Message Waiting Capability
- Display
- LCD display - monochrome - Yes
- Network Ports Qty
- 2 x Ethernet 10Base-T/100Base-TX/1000Base-T
- Compatible Software
- Cisco Unified Communications Manager 8.5.1 or later
- 1-year warranty
- Product Type
- VoIP phone
- Body Material
- PC/ABS
Phone Features
- Call Services
- Dialer Type
- Keypad
- Dialer Location
- Base
- Conference Call Capability
- Speakerphone
- Menu Operation
- Programmable Buttons Qty
- 4
- Indicators
- Voice message waiting indicator, speakerphone indicator, headset
- Firmware Upgradable
- Additional Functions
- Call timer
- Additional Features
- Music on hold
IP Telephony
- Main Features
- VoIP
- VoIP Protocols
- SIP, SRTP
- Voice Codecs
- Lines Supported
- 4 lines
- Quality of Service
- IEEE 802.1Q (VLAN), IEEE 802.1p
- IP Address Assignment
- DHCP, static
- Security
- IEEE 802.1X
- Power Over Ethernet (PoE) Support
- Network Protocols
- Cisco Discovery Protocol (CDP), SRTP
- Network Ports Qty
- Network Features
- Lightweight Directory Access Protocol (LDAP)
Display
- Display Location
- Base
- Diagonal Size
- 3.5"
- Display Resolution
- 396 x 162 pixels
- Backlit
- Display Languages
- Danish, Hebrew, Hungarian, Czech, Croatian, Slovenian, Thai, Slovak, Brazilian Portuguese, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Latvian, Lithuanian, Estonian, Serbian, Romanian, Catalan, Japanese, Chinese, Korean
- Connections
- Headset jack
- Placing / Mounting
- Wall-mountable, table-top
- CISPR 22 Class B, CISPR 24, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, ICES-003 Class B, AS/ACIF S004, FCC Part 68, EMC, CS-03, UL 60950-1 Second Edition, EN 60601-1-2, FCC CFR47 Part 15 B, GB 4943, AS/NZS 60950, CSA C22.2 No. 60950-1 Second Edition, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, VCCI Class B
Dimensions & Weight (Base)
- 20.6 cm
- 2.8 cm
- 20.7 cm
- 868 g
- Limited warranty - replacement - 1 year
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £8.56 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £10.73 |
Cisco Wallmount Kit for IP Phone 7821, 7841 | In Stock | £44.51 |
