Cisco IP Phone 7841 - VoIP Phone
Quicklinx: B6ZYWS00 Mfr#: CP-7841-K9=
Type: VoIP phone
Handsets Included: [N/A]
Answer Machine: [N/A]
Nuisance Call Blocker: No
Mounting: Wall-mountable, Table-top
32 In Stock
£212.59 ex VAT
£255.10 inc VAT
Deploy high-quality voice communications for your information workers, the administrative and managerial staff. The affordable Cisco IP Phone 7841 is full-featured and easy to use. Business calls are more efficient and productive, which fosters collaboration. The 7841 also supports wideband audio for superior voice quality and offers advanced IP communications features.
  • Versatile display options
    The Cisco IP Phone 7841 features a 3.5-inch monochrome LCD display, offering clear and crisp visuals. With backlight support, it ensures readability in various lighting conditions.
  • Comprehensive language support
    This device breaks language barriers with an extensive array of display languages ranging from Arabic to Turkish, catering to a global workforce.
  • Enhanced call management
    Equipped with functionalities like call forwarding, call hold, call transfer, and more, it streamlines communication for efficient workflow.
  • Robust connectivity
    With two Ethernet ports supporting speeds up to 1000Base-T and Power over Ethernet (PoE) support, the Cisco IP Phone 7841 ensures reliable connectivity and easy installation.
  • Advanced security features
    The phone incorporates IEEE 802.1X security, safeguarding your communications and ensuring peace of mind.
Cisco IP Phone 7841 - VoIP phone
VoIP phone
Compatible Platforms
Cisco Business Edition 6000
Main Features
Multiple VoIP protocol support, integrated Ethernet switch
VoIP Protocols
SIP, SRTP
Voice Codecs
G.722, G.729ab, G.711u, G.711a, iLBC
Lines Supported
4 lines
Speakerphone
Yes (digital duplex)
Call Services
Voice Mail, Caller ID, Call Waiting, Call Forwarding, Call Transfer, Call Hold, Message Waiting Capability
Display
LCD display - monochrome - Yes
Network Ports Qty
2 x Ethernet 10Base-T/100Base-TX/1000Base-T
Compatible Software
Cisco Unified Communications Manager 8.5.1 or later
1-year warranty
VoIP phone
Body Material
PC/ABS
Phone Features
Call Services
Dialer Type
Keypad
Dialer Location
Base
Conference Call Capability
Speakerphone
Menu Operation
Programmable Buttons Qty
4
Indicators
Voice message waiting indicator, speakerphone indicator, headset
Firmware Upgradable
Additional Functions
Call timer
Additional Features
Music on hold
IP Telephony
Main Features
VoIP
VoIP Protocols
SIP, SRTP
Voice Codecs
Lines Supported
4 lines
Quality of Service
IEEE 802.1Q (VLAN), IEEE 802.1p
IP Address Assignment
DHCP, static
Security
IEEE 802.1X
Power Over Ethernet (PoE) Support
Network Protocols
Cisco Discovery Protocol (CDP), SRTP
Network Ports Qty
Compatible Software
Network Features
Lightweight Directory Access Protocol (LDAP)
Display
Display Location
Base
Diagonal Size
3.5"
Display Resolution
396 x 162 pixels
Backlit
Display Languages
Danish, Hebrew, Hungarian, Czech, Croatian, Slovenian, Thai, Slovak, Brazilian Portuguese, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Latvian, Lithuanian, Estonian, Serbian, Romanian, Catalan, Japanese, Chinese, Korean
Headset jack
Placing / Mounting
Wall-mountable, table-top
CISPR 22 Class B, CISPR 24, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, ICES-003 Class B, AS/ACIF S004, FCC Part 68, EMC, CS-03, UL 60950-1 Second Edition, EN 60601-1-2, FCC CFR47 Part 15 B, GB 4943, AS/NZS 60950, CSA C22.2 No. 60950-1 Second Edition, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, VCCI Class B
Dimensions & Weight (Base)
20.6 cm
2.8 cm
20.7 cm
868 g
Limited warranty - replacement - 1 year
B6ZY C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.68
B6ZY C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £9.87
B6ZY Cisco Wallmount Kit for IP Phone 7821, 7841 In Stock £45.24
Type: VoIP phone
Mounting: Table-top
Big Button: No
Brand: Cisco
