Cisco IP Phone 7811 - VoIP phone - SIP, SRTP
Quicklinx: BVJZWS00 Mfr#: CP-7811-K9=
Type: VoIP phone
Handsets Included: 1
Answer Machine: [N/A]
Nuisance Call Blocker: No
Mounting: Wall-mountable, Table-top
17 In Stock
£135.95 ex VAT
£163.14 inc VAT
Invest in affordable and reliable voice communications with the Cisco IP Phone 7811. It is full-featured, highly secure, easy to use, and offers access to XML and CTI applications. The Cisco IP Phone 7811 is a single-line phone that is optimal for information workers and managers.
  • SINGLE LINE
    Ideal for light voice communications needs and common areas with occasional usage such as lobbies, cafeterias and conference centres
  • FIXED FUNCTION KEYS
    One-touch access to service, messaging, directory, hold/resume, transfer and conference features
  • FULLY PROGRAMMABLE
    Set up line keys to support either lines, such as directory numbers, or call features like speed dialling
  • OPTIMAL PERFORMANCE
    Class 1 PoE with 10/100BASE-T Ethernet connection through two RJ45 ports
  • PEACE OF MIND
    1-year limited hardware warranty
VoIP phone
Compatible Platforms
Cisco Business Edition 6000
Main Features
Multiple VoIP protocol support, integrated Ethernet switch
VoIP Protocols
SIP, SRTP
Voice Codecs
G.722, G.729a, G.711u, G.711a, iLBC
Speakerphone
Yes (digital duplex)
Call Services
Voice Mail, Caller ID, Call Waiting, Call Forwarding, Call Transfer, Call Hold, Message Waiting Capability
Display
LCD display - monochrome
Network Ports Qty
2 x Ethernet 10Base-T/100Base-TX
Compatible Software
Cisco Unified Communications Manager 8.5.1 or later, Cisco Hosted Collaboration Solution, Cisco Unified Survivable Remote Site Telephony 8 or later
1-year warranty
VoIP phone
Body Material
PC/ABS
Phone Features
Call Services
Dialer Type
Keypad
Dialer Location
Base
Conference Call Capability
Speakerphone
Menu Operation
Indicators
Voice message waiting indicator, speakerphone indicator
Firmware Upgradable
Additional Functions
Call timer
Additional Features
Music on hold
IP Telephony
Main Features
VoIP
VoIP Protocols
SIP, SRTP
Voice Codecs
Quality of Service
IEEE 802.1Q (VLAN), IEEE 802.1p
IP Address Assignment
DHCP, static
Security
128 bit AES, 256 bit AES, IEEE 802.1X, TLS
Power Over Ethernet (PoE) Support
Network Protocols
Cisco Discovery Protocol (CDP), SRTP
Network Ports Qty
Compatible Software
Network Features
Lightweight Directory Access Protocol (LDAP)
Display
Display Location
Base
Diagonal Size
3.28"
Display Resolution
384 x 106 pixels
Display Languages
Danish, Hebrew, Hungarian, Czech, Croatian, Slovenian, Thai, Slovak, Brazilian Portuguese, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Latvian, Lithuanian, Estonian, Serbian, Romanian, Catalan, Japanese, Chinese, Korean
Hearing Aid Compatible
Placing / Mounting
Wall-mountable, table-top
CISPR 22 Class B, CISPR 24, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, ICES-003 Class B, AS/ACIF S004, FCC Part 68, EMC, ADA, CS-03, UL 60950-1 Second Edition, EN 60601-1-2, FCC CFR47 Part 15 B, GB 4943, AS/NZS 60950, HAC (Hearing Aid Compatible), CSA C22.2 No. 60950-1 Second Edition, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, VCCI Class B, KN24, KCC KN22 Class B, AS/ACIF S040
Dimensions & Weight (Base)
20.7 cm
3.3 cm
20.7 cm
806 g
Limited warranty - replacement - 1 year
BVJZ C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £8.56
BVJZ C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.73
BVJZ C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £14.87
Type: VoIP phone
Mounting: Table-top
Big Button: No
Brand: Cisco
