Invest in affordable and reliable voice communications with the Cisco IP Phone 7811. It is full-featured, highly secure, easy to use, and offers access to XML and CTI applications. The Cisco IP Phone 7811 is a single-line phone that is optimal for information workers and managers.
SINGLE LINE
Ideal for light voice communications needs and common areas with occasional usage such as lobbies, cafeterias and conference centres -
FIXED FUNCTION KEYS
One-touch access to service, messaging, directory, hold/resume, transfer and conference features -
FULLY PROGRAMMABLE
Set up line keys to support either lines, such as directory numbers, or call features like speed dialling -
OPTIMAL PERFORMANCE
Class 1 PoE with 10/100BASE-T Ethernet connection through two RJ45 ports -
PEACE OF MIND
1-year limited hardware warranty
- Cisco IP Phone 7811 - VoIP phone
- Product Type
- VoIP phone
- Compatible Platforms
- Cisco Business Edition 6000
- Main Features
- Multiple VoIP protocol support, integrated Ethernet switch
- VoIP Protocols
- SIP, SRTP
- Voice Codecs
- G.722, G.729a, G.711u, G.711a, iLBC
- Speakerphone
- Yes (digital duplex)
- Call Services
- Voice Mail, Caller ID, Call Waiting, Call Forwarding, Call Transfer, Call Hold, Message Waiting Capability
- Display
- LCD display - monochrome
- Network Ports Qty
- 2 x Ethernet 10Base-T/100Base-TX
- Compatible Software
- Cisco Unified Communications Manager 8.5.1 or later, Cisco Hosted Collaboration Solution, Cisco Unified Survivable Remote Site Telephony 8 or later
- 1-year warranty
- Product Type
- VoIP phone
- Body Material
- PC/ABS
Phone Features
- Call Services
- Dialer Type
- Keypad
- Dialer Location
- Base
- Conference Call Capability
- Speakerphone
- Menu Operation
- Indicators
- Voice message waiting indicator, speakerphone indicator
- Firmware Upgradable
- Additional Functions
- Call timer
- Additional Features
- Music on hold
IP Telephony
- Main Features
- VoIP
- VoIP Protocols
- SIP, SRTP
- Voice Codecs
- Quality of Service
- IEEE 802.1Q (VLAN), IEEE 802.1p
- IP Address Assignment
- DHCP, static
- Security
- 128 bit AES, 256 bit AES, IEEE 802.1X, TLS
- Power Over Ethernet (PoE) Support
- Network Protocols
- Cisco Discovery Protocol (CDP), SRTP
- Network Ports Qty
- Network Features
- Lightweight Directory Access Protocol (LDAP)
Display
- Display Location
- Base
- Diagonal Size
- 3.28"
- Display Resolution
- 384 x 106 pixels
- Display Languages
- Danish, Hebrew, Hungarian, Czech, Croatian, Slovenian, Thai, Slovak, Brazilian Portuguese, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Latvian, Lithuanian, Estonian, Serbian, Romanian, Catalan, Japanese, Chinese, Korean
- Hearing Aid Compatible
- Placing / Mounting
- Wall-mountable, table-top
- CISPR 22 Class B, CISPR 24, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, ICES-003 Class B, AS/ACIF S004, FCC Part 68, EMC, ADA, CS-03, UL 60950-1 Second Edition, EN 60601-1-2, FCC CFR47 Part 15 B, GB 4943, AS/NZS 60950, HAC (Hearing Aid Compatible), CSA C22.2 No. 60950-1 Second Edition, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, VCCI Class B, KN24, KCC KN22 Class B, AS/ACIF S040
Dimensions & Weight (Base)
- 20.7 cm
- 3.3 cm
- 20.7 cm
- 806 g
- Limited warranty - replacement - 1 year
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.80 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £12.76 |
