Cisco Integrated Services Router 1111 4-port Router
Quicklinx: DTLHWS00 Mfr#: C1111-4P
More than 50 In Stock
£752.70 ex VAT
£903.24 inc VAT
Cisco 1100 Series Integrated Services Routers (ISRs) are easy to deploy and manage, with cutting-edge, scalable, multicore separate data and control plane capabilities. The Cisco 1100 Series ISRs are well suited for deployment as Customer Premises Equipment (CPE) in enterprise branch offices, in service provider managed environments as well as smaller form factor and M2M use cases.
  • PORT COUNT
    4-port managed Gigabit Ethernet switch (2 ports PoE capable with 1 port PoE+)
  • CONNECTIVITY
    Gigabit WAN and WAN/SFP combo ports with integrated USB 3.0 AUX/console
  • SECURITY
    Multi-layer, robust security and high-performance VPNs encrypt all data from the WAN edge to the cloud
  • PERFORMANCE
    Business router designed for broadband network speeds while running secure, concurrent data, voice, video and wireless services
  • PEACE OF MIND
    1-year limited hardware warranty with 10-day advanced replacement
Cisco Integrated Services Router 1111 - router - desktop
Router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Performance
Encryption throughput: 250 Mbps
Network / Transport Protocol
IPSec, PPPoE, DHCP, DNS, L2TPv3
Routing Protocol
OSPF, IS-IS, RIP-1, RIP-2, BGP, EIGRP, HSRP, DVMRP, VRRP, PIM-SM, static IP routing, IGMPv3, GRE, PIM-SSM, policy-based routing (PBR), MPLS, Bidirectional Forwarding Detection (BFD), RSVP
Remote Management Protocol
SNMP, RMON, CLI, TR-069
CBWFQ, WRED, ACL support, QoS, DMVPN, 2T2R MIMO technology, NetFlow, MRC, IPFIX, CSD, LISP, packet aggregation A-MPDU, packet aggregation A-MSDU, MIB II, AVC, AAA, DFS, ERSPAN, EEM
IEEE 802.3af, IEEE 802.11i, IEEE 802.3ah, IEEE 802.1ag, IEEE 802.3at, IEEE 802.11r
32.3 cm x 23 cm x 4.2 cm
2.59 kg
Enclosure Type
Desktop
Wireless, wired
Performance
Routing Protocol
Encryption Algorithm
DES, Triple DES, SHA, MD5, IKE, ECDSA, 128-bit AES, 256-bit AES, 1024-bit RSA, 2048-bit RSA, 256-bit SHA, 512-bit SHA, 748-bit RSA, 384-bit SHA
Authentication Method
RADIUS
IEEE 802.3af, IEEE 802.11i, IEEE 802.3ah, IEEE 802.1ag, IEEE 802.3at, IEEE 802.11r, CISPR 24, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, CB, EN 61000-6-1, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, EN 61000-4-5, EN 61000-4-11, FCC CFR47 Part 15, UL 60950-1 Second Edition, VCCI V-3, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, AS/NZS CISPR 22, CNS 13438, EN 301 489-7, EN 301 489-1, FCC CFR47 Part 22, FCC CFR47 Part 24, CAN/CSA C22.2 No. 60950-1 Second Edition, EN 300 386, EN 301 489-24, EN 301 908-1, EN 301 908-2, EN 301 511, EN 301 908-13
RAM
4 GB
Flash Memory
4 GB
Status Indicators
Status
WAN: 1 x 1000Base-T/1000Base-X - RJ-45/SFP , LAN: 2 x 1000Base-T - RJ-45 , LAN: 1 x 1000Base-T (PoE+) - RJ-45 , LAN: 1 x 1000Base-T (PoE) - RJ-45 , USB 3.0: 1 x
32.3 cm
23 cm
4.2 cm
2.59 kg
65 °C
5 - 95% (non-condensing)
Accessories (1)
Get the most from your Router
DTLH Cisco 1000BASE-T SFP Transceiver In Stock £185.12
Other bundles (1)
DTLH Cisco AC Power Cord In Stock £40.14
Type: Router
Standards: Gigabit Ethernet
Standards: Fast Ethernet
Standards: Ethernet
Brand: Cisco
Price Range Ex VAT: £750 - £1000
