Cisco IE 2000 switch 8x 10/100,2 T/SFP, Base IOS
Quicklinx: B899WS00 Mfr#: IE-2000-8TC-G-B
Type: Gigabit Ethernet
Ports: 10
Data Transfer Rate: 100Mbps
Managed: Yes
POE: No
£1,223.24 ex VAT
£1,467.88 inc VAT
The Cisco Industrial Ethernet 2000 (IE 2000) series is a range of compact, industrially ruggedized access switches. IE 2000 series provides customers with ease of use, secure access, and industry leading convergence using Cisco Resilient Ethernet Protocol (REP). Multiple industries such as automotive, oil and gas, mining, transportation, and energy companies are all increasingly requiring IP based networks in their production areas. The IE 2000 additions have been designed to support access layer connectivity and to meet the increasing needs for security, voice, and video traffic across industrial networks.
  • Easy deployment
    Zero-touch discovery using DHCP, express setup, fast bootup time to help migrating to Ethernet environment without resistance.
  • Security
    Dot1x, port security, and DHCP allow dynamic port-base authentication, Secure Shell (SSHv2), SNMPv3 provides encrypted administrator traffic during Telnet and SNMP sessions, TACACS+ and RADIUS authentication facilitate centralized control and restrict unauthorized users.
  • Resiliency
    Flex links for fast recovery, Cisco REP protocol for fast convergence.
  • Industrial automation protocols
    Support for Common Industrial Protocol (CIP) and PROFINETv2 that allow integration with existing management platform from Rockwell, Siemens, and other industrial environments.
Cisco Industrial Ethernet 2000 Series - switch - 10 ports - Managed
Switch - 10 ports - Managed
Subtype
Gigabit Ethernet
Ports
8 x 10/100 + 2 x combo Gigabit SFP
Performance
Forwarding performance (64-byte packet size): 6.5 Mpps
Virtual interfaces (VLANs): 255
MAC Address Table Size
8K entries
Routing Protocol
IGMP, static IPv4 routing
Remote Management Protocol
SNMP 3, HTTPS, SSH
DHCP support, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, STP support, RSTP support, QoS, Port Security, RSPAN
IEEE 802.1x
1-year warranty
Enclosure Type
DIN rail mountable
Subtype
Gigabit Ethernet
Ports
Performance
8K entries
Routing Protocol
SNMP 3, HTTPS, SSH
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+
IEEE 802.1x
RAM
256 MB
Flash Memory
64 MB
8 x 100Base-TX RJ-45 , 2 x SFP (mini-GBIC) , 2 x 1000Base-T RJ-45
Expansion Slots
1 (total) / 1 (free) x SD Memory Card
Rack Mounting Kit
Optional
MTBF
374,052 hours
C-Tick, CISPR 22 Class A, CISPR 24, IEC 61000-4-11, VCCI Class A ITE, EN55022 Class A, EN 61000-6-1, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, ICES-003 Class A, EN 61000-4-5, RoHS, FCC CFR47 Part 15, EN 61000-4-8, UL 60950-1, IEC 60950-1, EN 60950-1, EN 61000-6-4, IEC 60068-2-30, KCC, IEC 60068-2-27, IEC 60068-2-6, UL 508, FCC Part 15 A, IEC 60529 IP30, CISPR 11, CSA 22.2 No. 142, EN 61131-2, EN 61326-1, EN 61000-4-9, EN 61000-4-29, IEC 60068-2-14
Software Included
Cisco IOS LAN Base
Limited warranty - 1 year
5 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
Ports: 10
Managed: Yes
POE: No
Brand: Cisco
Price Range Ex VAT: £1000 - £1500
