Brand
Cisco Gigabit Ethernet LX Mini-GBIC SFP Transceiver
Quicklinx: 7TJ3WS00 Mfr#: MGBLX1
Type: Modules
13 in stock
£148.66 ex VAT
£178.39 inc VAT
Cisco MGE Small Form-Factor Pluggable (SFP) is easy-to-install module that provides a simple way to add fiber connectivity or to add an extra Gigabit Ethernet port to your Cisco Small Business Series switches.
The Cisco MGE transceiver provides fast and reliable connectivity between switches that are located on different floors, in separate buildings, or on a small campus network needing connectivity between sites. The transceiver can support both Fast and Gigabit Ethernet applications.
  • ADDS FIBER
    Optic connectivity to Cisco 100 to 500 Series switches
  • CONNECTIVITY
    1000BASE-LX SFP transceiver for single-mode fiber, 1310 nm wavelength, supports up to 10 km
  • DURABLE AND LOW POWER CONSUMPTION
    Less power usage and heat-conducting increases the life of the product
  • EASY TO USE
    Easy installation, plug and play, fully hot-swapple
  • PEACE OF MIND
    5-year warranty and one-year technical support
Cisco Small Business MGBLX1 - SFP (mini-GBIC) transceiver module - GigE
SFP (mini-GBIC) transceiver module - LC single-mode
Plug-in module
Cabling Type
1000Base-LX
Data Transfer Rate
1 Gbps
Optical Wave Length
1310 nm
GigE
Max Transfer Distance
10 km
1.3 cm x 5.6 cm x 0.9 cm
18 g
250 Series; Business 110 Series; 220 Series; 350 Series; Small Business SF 100-16, SF 100D-05, SF 100D-08, SF 100D-16, SF 100D-16 V2, SF 102-24, SF110, SF112, SF300, SF302, SF350, SF352, SF500, SG 100-16, SG 100-24, SG 100D-05, SG 100D-08, SG 102-24, SG110, SG112, SG250, SG300, SG350, SG355, SG500
Plug-in module
Wired
Cabling Type
1000Base-LX
GigE
Data Transfer Rate
1 Gbps
Optical Wave Length
1310 nm
10 km
1 x Ethernet 1000Base-LX - LC single-mode x 2
Compatible Slots
1 x SFP (mini-GBIC)
VCCI Class B ITE, CISPR 22 Class B, EN 60950, EN55022 Class B, FCC Part 15 B, EN 60825, IEC 60825-1, FDA
1.3 cm
5.6 cm
0.9 cm
18 g
70 °C
10 - 85%
Cisco 250 Series SG250X-48P , Cisco Business 110 Series 110-24T, 110-8T-D , Cisco Business 220 Series CBS220-24P-4X , Cisco Business 350 Series 350-24FP-4G, 350-24T-4G, 350-48T-4G, 350-8T-E-2G , Cisco Small Business SF 100-16, SF 100-24, SF 100D-05, SF 100D-08, SF 100D-08P, SF 100D-16, SF 100D-16 V2, SF 100D-16P, SF 102-24, SF110-16, SF110-24, SF110D-05, SF110D-08, SF110D-08HP, SF110D-16, SF110D-16HP, SF112-24, SF300-08, SF300-24, SF300-24MP, SF300-24P, SF300-24PP, SF300-48, SF300-48P, SF300-48PP, SF302-08, SF302-08MP, SF302-08MPP, SF302-08P, SF302-08PP, SF350-08, SF350-24, SF350-24MP, SF350-24P, SF350-48, SF350-48MP, SF350-48P, SF352-08, SF352-08MP, SF352-08P, SF352-08P-K9, SF500-24, SF500-24MP, SF500-24P, SF500-48, SF500-48MP, SF500-48P, SG 100-16, SG 100-24, SG 100D-05, SG 100D-08, SG 100D-08P, SG 102-24, SG110-16, SG110-16HP, SG110-24, SG110-24HP, SG110D-05, SG110D-08, SG110D-08HP, SG112-24, SG250-08, SG250-08HP, SG250-10P, SG250-18, SG250X-24, SG250X-24P, SG250X-48, SG250X-48P, SG300-10, SG300-10MP, SG300-10MPP, SG300-10P, SG300-10PP, SG300-10SFP, SG300-20, SG300-24PP, SG300-28, SG300-28MP, SG300-28P, SG300-28PP, SG300-28SFP, SG300-52, SG300-52MP, SG300-52P, SG350-10, SG350-10MP, SG350-10P, SG350-10SFP, SG350-20, SG350-28, SG350-28MP, SG350-28P, SG350-28SFP, SG350-52, SG350-52MP, SG350-52P, SG350-8PD, SG350X-12PMV, SG350X-24, SG350X-24MP, SG350X-24P, SG350X-24PD, SG350X-24PV, SG350X-48, SG350X-48MP, SG350X-48P, SG350X-48PV, SG350X-8PMD, SG350XG-24F, SG350XG-24T, SG350XG-2F10, SG350XG-48, SG350XG-48T, SG355-10P, SG500-28, SG500-28MPP, SG500-28P, SG500-52, SG500-52MP, SG500-52P, SG500X-24, SG500X-24MPP, SG500X-24P, SG500X-48, SG500X-48MP, SG500X-48P, SG500XG-8F8T
Type: Modules
Brand: Cisco
Stock Status: In stock
