Keep your employees, your business, and yourself productive and effective. The Cisco RV320 Dual Gigabit WAN VPN Router is an ideal choice for any small office or small business looking for performance, security, and reliability in its network.
Performance
Cisco RV320 Dual Gigabit WAN VPN Router supports Gigabit Ethernet speeds for internal and external wired connections; easily manages large files and concurrent users to keep employees productive. -
Simple, highly secure access
Connect multiple locations and remote workers using VPN, or set up separate virtual networks and access rules to help secure sensitive data. -
Ease of use
Can be deployed directly out of the box; setup wizards reduce configuration time to minutes. -
Flexible
USB ports provide the ability to use 3G and 4G modems for broadband failover.
- Cisco Small Business RV320 - router - desktop
- Router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 2
- Data Link Protocol
- Performance
- NAT throughput: 900 Mbps , VPN throughput (IPSec): 100 Mbps , VPN throughput (SSL): 20 Mbps
- Capacity
- Virtual interfaces (VLANs): 16 , PPTP VPN tunnels: 10 , SSL VPN tunnels: 10 , VPN tunnels (site-to-site): 25 , IPSec VPN tunnels: 25 , Concurrent connections: 20000
- PPTP, L2TP, IPSec, PPPoE, DHCP, Bonjour, DDNS
- Routing Protocol
- RIP-1, RIP-2, static IP routing, RIPng
- Remote Management Protocol
- SNMP 1, SNMP 3, SNMP 2c, HTTP, HTTPS
- DMZ port, NAT support, hardware encryption, VPN support, PAT support, load balancing, Syslog support, SPI, DoS attack prevention, content filtering, E-mail alert, IPv6 support, firmware upgradable, QoS, IPSec NAT-T, DHCP server, reset button, bandwidth control, DHCP relay, DNS relay, DHCP client
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q
- 20.6 cm x 13.2 cm x 4.4 cm
- Limited lifetime warranty
- Enclosure Type
- Desktop
- Connectivity Technology
- Wired
- Performance
- Capacity
- Routing Protocol
- Encryption Algorithm
- DES, Triple DES, MD5, SHA-1, 128-bit AES, 192-bit AES, 256-bit AES
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, FCC Class B certified, UL, BSMI, cUL, CB, CCC, ANATEL, KC
- Status Indicators
- Port transmission speed, power, WAN, DMZ, link/activity, DMZ/Internet, diagnostic, USB, VPN
- LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN / DMZ: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 2 x 4 pin USB Type A
- Power Device
- External power adapter
- Cables Included
- 1 x network cable
- Software Included
- Drivers & Utilities
- 20.6 cm
- 13.2 cm
- 4.4 cm
- Limited warranty - lifetime
- 0 °C
- 40 °C
- 10 - 85% (non-condensing)
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.74 |
C2G 12m USB 2.0 A/A Active Extension Cable | In Stock | £18.86 |
