Cisco Four-Point Rack Mounting Kit
Quicklinx: 84B6WS00 Mfr#: C3KX-4PT-KIT=
The 19-inch brackets are included with the switch. Installing the switch in other rack types requires an optional bracket kit not included with the switch.
  • Efficient compatibility
    Designed specifically for PC compatibility, the Cisco Four-Point Rack Mounting Kit seamlessly integrates into your existing setup, ensuring a perfect fit and optimal performance.
  • Standardized sizing
    With a rack size of 19" and a metric equivalent of 48.3 cm, this mounting kit adheres to industry standards, offering a universal solution for your rack and rack hardware needs.
Cisco Four-Point Rack Mounting Kit - rack mounting kit - 19"
Rack mounting kit
Catalyst 3560X-24, 3560X-48, 3750X-12, 3750X-24, 3750X-48
Rack mounting kit
Rack Size
19"
Cisco Catalyst 3560X-24P-L, 3560X-24P-S, 3560X-24T-L, 3560X-24T-S, 3560X-48PF-L, 3560X-48PF-S, 3560X-48P-L, 3560X-48P-S, 3560X-48T-L, 3560X-48T-S, 3750X-12S-E, 3750X-12S-S, 3750X-24P-L, 3750X-24P-S, 3750X-24S-E, 3750X-24S-S, 3750X-24T-L, 3750X-24T-S, 3750X-48PF-L, 3750X-48PF-S, 3750X-48P-L, 3750X-48P-S, 3750X-48T-L, 3750X-48T-S
