- Tamron CCTV lens - 5 mm - 50 mm
- Lens System
- CCTV lens
- CCTV
- Vari-focal - 1/3" - CS-mount
- Intended For
- Surveillance
- Focal Length
- 5 mm - 50 mm
- Optical Zoom
- 10 x
- Designed For
- P/N: CIVS-IPC-2500, CIVS-IPC-2500W, PVC2300, PVC2300-AU, PVC2300-EU, WVC2300, WVC2300-AU, WVC2300-EU, WVC2300-G5
Lens System
- CCTV lens
- Intended For
- Surveillance
- Focal Length
- 5 mm - 50 mm
- Optical Zoom
- 10 x
CCTV
- Equipment Category
- Lenses - CS-mount - vari-focal
- Sensor Compatibility
- 1/3"
- Designed For
