Cisco Cisco FlexStack-Plus Network stacking module
Quicklinx: 9B0NWS00 Mfr#: C2960X-STACK=
Type: Modules
£798.94 ex VAT
£958.72 inc VAT
Cisco Catalyst 2960-X switches are fixed-configuration, stackable Gigabit Ethernet switches that provide enterprise-class access for campus and branch applications. Designed for operational simplicity to lower total cost of ownership, they enable scalable, secure and energy-efficient business operations with intelligent services and a range of advanced Cisco IOS software features.
  • Enhanced connectivity
    The Cisco FlexStack-Plus provides two network stack devices and stack ports, ensuring robust and flexible network connectivity options for comprehensive system integration.
  • Seamless integration
    Designed as a plug-in module, this network stacking module is compatible with PCs, allowing for seamless integration into existing network infrastructures without the need for extensive modifications.
  • Reliable performance
    Featuring hot swap module replacement, the Cisco FlexStack-Plus ensures minimal downtime and reliable performance, making it an essential component for maintaining continuous network operations.
Cisco FlexStack-Plus - network stacking module
Plug-in module
Catalyst 2960X-24, 2960X-48, 2960XR-24, 2960XR-48
Plug-in module
Wired
Hot swap module replacement
2 x stack port
Compatible Slots
1 x Expansion Slot
Cisco Catalyst 2960X-24PD-BA, 2960X-24PD-L, 2960X-24PS-L, 2960X-24PSQ-L, 2960X-24PS-S, 2960X-24TD-BA, 2960X-24TD-L, 2960X-24TS-L, 2960X-24TS-LL, 2960X-48FPD-BA, 2960X-48FPD-L, 2960X-48FPS-L, 2960X-48LPD-L, 2960X-48LPS-L, 2960X-48TD-L, 2960X-48TS-L, 2960XR-24PD-I, 2960XR-24PS-I, 2960XR-24TD-I, 2960XR-24TS-I, 2960XR-48FPD-I, 2960XR-48FPS-I, 2960XR-48LPD-I, 2960XR-48LPS-I, 2960XR-48TD-I, 2960XR-48TS-I
Type: Modules
Brand: Cisco
Price Range Ex VAT: £750 - £1000
