Cisco Cisco Aironet Dual-Band Dipole Antenna - Antenna - indoor -
Quicklinx: 96H6WS00 Mfr#: AIR-ANT2524DB-R=
Type: Antennas
£28.86 ex VAT
£34.63 inc VAT
As this access point takes greater advantage of the multiple-input multiple-output (MIMO) features supported under the 802.11n standard, the number of radio transceivers per frequency band has increased. Using dual-band antenna port allows the access point to support these added transceivers while maintaining a reasonably low number of antenna connections.
  • Versatile placement
    Designed for indoor use, this antenna can be easily mounted in various settings, ensuring optimal signal reception and broadcast within any indoor environment.
  • Dual-band functionality
    With the ability to operate on both 2.4 GHz and 5 GHz frequencies, this antenna offers flexibility for network configuration, supporting a wide range of wireless applications.
  • Enhanced signal gain
    Featuring a gain of 2 dBi for 2.4 GHz and 4 dBi for 5 GHz, this antenna enhances signal strength and quality, providing reliable wireless connectivity for all connected devices.
Cisco Aironet Dual-Band Dipole Antenna - antenna
Antenna
Aerial Placing / Mounting
Indoor
Frequency Range
2.4 GHz, 5 GHz
Gain
2 dBi, 4 dBi
Aironet 3602E
Antenna
Enclosure Colour
Aerial
Indoor
Frequency Range
2.4 GHz, 5 GHz
Gain
2 dBi, 4 dBi
Cisco Aironet 3602E
Type: Antennas
Brand: Cisco
