Cisco Cisco 2911 Security Bundle w/SEC license PAK
Quicklinx: 7RT9WS00 Mfr#: CISCO2911-SEC/K9
The platforms are architected to enable the next phase of branch-office evolution, providing rich media collaboration and virtualization to the branch while maximizing operational cost savings The integrated services routers generation 2 platforms are future-enabled with multi-core CPUs, support for high capacity DSPs (Digital Signal Processors) for future enhanced video capabilities, high powered service modules with improved availability, Gigabit Ethernet switching with enhanced POE, and energy monitoring and control capabilities while enhancing overall system performance. Overall, the Cisco 2900 series offer unparalleled total cost of ownership savings and network agility through the intelligent integration of market leading security, unified communications, wireless, and application services.
The Cisco 2900 series integrated services router offers embedded hardware encryption acceleration, voice- and video-capable Digital Signal Processor (DSP) slots, intrusion prevention, call processing, voicemail, and application services.
  • Services integration
    The Cisco 2900 series ISRs offer increased levels of services integration with voice, video, security, wireless, mobility, and data services, enabling greater efficiencies and cost savings.
  • Services on demand
    The Universal image contains all of the Cisco IOS technology sets which can be activated with a software license. This allows your business to quickly deploy advanced features without downloading a IOS image. Additionally, larger default memory is included to support the capabilities.
  • High performance with integrated services
    The Cisco 2900 series enables deployment in high speed WAN environments with concurrent services enabled up to 75 Mbps. A multigigabit fabric (MGF) enables high-bandwidth module-to-module communication without compromising routing performance.
  • Network agility
    Designed to address customer business requirements, the Cisco 2900 series modular architecture offers increased capacity and performance as your network needs grow. Modular interfaces offer increased bandwidth, a diversity of connection options, and network resiliency.
  • Energy efficiency
    The Cisco 2900 series offers intelligent power management and allows the customer to control power to the modules based on the time of day. Cisco EnergyWise technology will be supported in the future. Services integration and modularity on a single platform performing multiple functions, optimizes raw materials consumption and energy usage.
Cisco 2911 Security Bundle - router - rack-mountable
Router
Enclosure Type
Rack-mountable - modular - 2U
WAN Ports Qty
3
Network / Transport Protocol
IPSec
Routing Protocol
OSPF, IS-IS, BGP, EIGRP, DVMRP, PIM-SM, IGMPv3, GRE, PIM-SSM, static IPv4 routing, static IPv6 routing
Remote Management Protocol
SNMP, RMON
Firewall protection, hardware encryption, VPN support, MPLS support, Syslog support, content filtering, IPv6 support, CBWFQ, WRED, DMVPN
IEEE 802.1Q, IEEE 802.3af, IEEE 802.3ah, IEEE 802.1ah, IEEE 802.1ag
43.8 cm x 30.5 cm x 8.9 cm
8.2 kg
90 days warranty
Router
Enclosure Type
Wired
IPSec
Routing Protocol
SNMP, RMON
Encryption Algorithm
SSL
IEEE 802.1Q, IEEE 802.3af, IEEE 802.3ah, IEEE 802.1ah, IEEE 802.1ag, CISPR 22 Class A, CISPR 24, EN55024, EN55022 Class A, EN50082-1, CAN/CSA-E60065-00, ICES-003 Class A, CS-03, AS/NZS 3548, FCC CFR47 Part 15, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60065, BSMI CNS 13438, EN 300 386
RAM
512 MB (installed) / 2 GB (max)
Flash Memory
256 MB (installed) / 8 GB (max)
Status Indicators
Power, link/activity
3 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , Management: 1 x console - RJ-45 , Management: 1 x console - mini-USB Type B , Serial: 1 x auxiliary - RJ-45 , USB: 2 x 4 pin USB Type A
Expansion Slots
4 (total) / 4 (free) x HWIC , 2 (total) / 2 (free) x PVDM , 2 (total) / 1 (free) x CompactFlash , 1 (total) / 1 (free) x expansion slot
Internal power supply
Rack Mounting Kit
Included
Software Included
Cisco IOS Security
43.8 cm
30.5 cm
8.9 cm
8.2 kg
Limited warranty - 90 days
5 - 85%
7RT9 C2G 2m USB 2.0 A/B Cable - Black In Stock £4.03
