- Cisco - power supply - hot-plug / redundant - 350 watt
- Power supply - hot-plug / redundant - plug-in module
- 1.2 kg
- Input Voltage
- AC 100-240 V
- Output Voltage
- -56 V
- Power Capacity
- 350 watt
- Input Connectors
- Power IEC 60320 C16
- 8.3 cm x 31 cm x 4 cm
- Designed For
- Catalyst 3850-12S-E, 3850-12S-S, 3850-12S-X, 3850-12XS-E, 3850-12XS-S, 3850-16XS-E, 3850-16XS-S, 3850-24S-E, 3850-24S-S, 3850-24T-E, 3850-24T-L, 3850-24T-S, 3850-48T-BA, 3850-48T-E, 3850-48T-L, 3850-48T-S, 9300 (350 watt), 9300L (350 watt); ONE Catalyst 3850-12S, 3850-12XS-S, 3850-24S, 3850-24T
- Input Voltage
- AC 100-240 V
- Frequency Required
- 50 - 60 Hz
- Input Connectors
- Output Voltage
- -56 V
- Power Capacity
- 350 watt
- CISPR 22 Class A, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class A, EN50082-1, EN 61000-6-1, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, AS/NZ 3548 Class A, CCC, ICES-003 Class A, EN 61000-4-5, UL 60950-1, IEC 60950-1, EN 60950-1, FCC Part 15 A, CSA C22.2 No. 60950-1, BSMI Class A, VCCI Class A, EN 300 386
- -5 °C
- 45 °C
- 5 - 90% (non-condensing)
- 8.3 cm
- 31 cm
- 4 cm
- 1.2 kg
- Designed For
- Cisco Catalyst 3850-12S-E (350 watt), 3850-12S-S (350 watt), 3850-12S-X (350 watt), 3850-12XS-E (350 watt), 3850-12XS-S (350 watt), 3850-16XS-E (350 watt), 3850-16XS-S (350 watt), 3850-24S-E (350 watt), 3850-24S-S (350 watt), 3850-24T-E (350 watt), 3850-24T-L (350 watt), 3850-24T-S (350 watt), 3850-48T-BA (350 watt), 3850-48T-E (350 watt), 3850-48T-L (350 watt), 3850-48T-S (350 watt), 9300 (350 watt), 9300L (350 watt) , Cisco ONE Catalyst 3850-12S (350 watt), 3850-12XS-S (350 watt), 3850-24S (350 watt), 3850-24T (350 watt)
Cisco Power Cable for Catalyst 3850-24 | In Stock | £40.28 |
Cisco Connectors/Cabinet Power Cord 250 VAC | In Stock | £21.11 |
