Cisco Catalyst power supply 350Watt
Quicklinx: C2NWWS00 Mfr#: PWR-C1-350WAC=
£410.90 ex VAT
£493.08 inc VAT
Cisco - power supply - hot-plug / redundant - 350 Watt
Power supply - hot-plug / redundant - plug-in module
1.2 kg
Input Voltage
AC 100-240 V
Output Voltage
-56 V
Power Capacity
350 Watt
Input Connectors
Power IEC 60320 C16
8.3 cm x 31 cm x 4 cm
Catalyst 3850-12S-E, 3850-12S-S, 3850-12S-X, 3850-12XS-E, 3850-12XS-S, 3850-16XS-E, 3850-16XS-S, 3850-24S-E, 3850-24S-S, 3850-24T-E, 3850-24T-L, 3850-24T-S, 3850-48T-BA, 3850-48T-E, 3850-48T-L, 3850-48T-S, 9300 (350 Watt), 9300L (350 Watt); ONE Catalyst 3850-12S, 3850-12XS-S, 3850-24S, 3850-24T
Input Voltage
AC 100-240 V
Frequency Required
50 - 60 Hz
Input Connectors
Power IEC 60320 C16
Output Voltage
-56 V
Power Capacity
350 Watt
CISPR 22 Class A, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class A, EN50082-1, EN 61000-6-1, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, AS/NZ 3548 Class A, CCC, ICES-003 Class A, EN 61000-4-5, UL 60950-1, IEC 60950-1, EN 60950-1, FCC Part 15 A, CSA C22.2 No. 60950-1, BSMI Class A, VCCI Class A, EN 300 386
-5 °C
45 °C
5 - 90% (non-condensing)
8.3 cm
31 cm
4 cm
1.2 kg
Cisco Catalyst 3850-12S-E (350 Watt), 3850-12S-S (350 Watt), 3850-12S-X (350 Watt), 3850-12XS-E (350 Watt), 3850-12XS-S (350 Watt), 3850-16XS-E (350 Watt), 3850-16XS-S (350 Watt), 3850-24S-E (350 Watt), 3850-24S-S (350 Watt), 3850-24T-E (350 Watt), 3850-24T-L (350 Watt), 3850-24T-S (350 Watt), 3850-48T-BA (350 Watt), 3850-48T-E (350 Watt), 3850-48T-L (350 Watt), 3850-48T-S (350 Watt), 9300 (350 Watt), 9300L (350 Watt) , Cisco ONE Catalyst 3850-12S (350 Watt), 3850-12XS-S (350 Watt), 3850-24S (350 Watt), 3850-24T (350 Watt)
C2NW Cisco Power Cable for Catalyst 3850-24 In Stock £40.28
C2NW Cisco Connectors/Cabinet Power Cord 250 VAC In Stock £19.94
Brand: Cisco
